0 members (),
132
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 42 New Guy | | New Guy Joined: Feb 2011 Posts: 42 | What's the proper procedure for painting leaf springs? My springs on my '61 K-10 short fleet have worn grooves into themselves. Do I take them apart to clean and paint, or just leave them where they're happy and just blast and paint them whole? Thanks for the help.
Matt | | | | | Joined: Aug 2004 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 56 | Hey, I posted the same message in the hope of getting a response for us. Good Luck. G. Lee | | | | | Joined: Feb 2000 Posts: 5,197 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,197 | Don't blast them whole, the sand will work its way in between each leaf and act like a grinder. It will bind them up and grind them down at the same time! Carefully pull them apart enough to blast and clean each leaf. The clips may hold some of them together, but you still should be able to get them clean after a good blasting. Joe | | |
