2 members (TexasA&M48Truck, Nick in Manitou), 124 guests, and 3 robots.
Topics128,082
Posts1,055,964
Members48,430
#1137996 12/05/2015 11:41 PM
can someone send a pic of how the oil bath air cleaner is set up on a 283 engine. does it work as well as putting a new air cleaner on the rig? I perfer the original equipment. thanks.
what means "set up"?
like any air cleaner, if it fits the carb, put it on and tighten the clamp .... depending on what you can find, looks like this on a 58 283 or like this on a 57 .... an oil bath works better than a dry filter in particularly dusty conditions
Here is an older thread related to the subject. Might help some. Pictures of the from the 60 shop manual and the physical air cleaner that I have on a 62.
http://s1377.photobucket.com/user/douglashamilton1/slideshow/283
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1125144/Re:_Oil_Bath_Air_Cleaner.html#Post1125144
~ HB
1962 Chevrolet C10
1962 Suburban
Oil bath is a great system. It does take a little extra to pull the air through it than a dry filter, but it works well.
Works Well?
When volcanoes fill the air with ash they are about all that works... I'd call that great!
Give me ambiguity
or give me something else
Oil bath air filters do in fact work well. Most real fine dirt is trapped in the oil(even the micro-fine stuff. The only issue might be airflow. Ever wonder why the filter is so big? Problem solved. Same tech. is used by K and N performance filters. When I raced in wet, or dusty conditions we used an oil soaked "sock" to wrap around the dry paper filters to protect the paper. Skip the paper and drive happy. The "mesh" element traps a lot of dirt because it is "wet" Air gets a free pass. Dirt gets stuck. Why did we go to replacement paper filters? No mess and no skill to replace. When does any one clean a filter these days? K and N uses a cotton fiber to replace the mesh and an oil spray to replace the "bath". They work well too.
Steve H
