6 members (FAST55, mick53, 50Chevy3100, baldeagle, Donf, TUTS 59), 64 guests, and 2 robots.
Topics128,014
Posts1,055,332
Members48,419
I need to replace the coil wire inside the armored sheath in the ignition switch assembly from a 1941 Chevy.
I disassembled the switch by prying back the three tabs holding the switch body together. This revealed a bakelite block with the switch contacts on the front and the wire connection and terminal studs on the back.
How do you remove the bakelite block to access the wire connection?
Ex Hall Monitor
Ex Hall Monitor
The Filling Station sells a rebuild manual that should answer your questions.
I don't have the books handy today but earlier in the week I was looking for info on another ignition related issue. In several of my old books they explained the system you're asking about and how to service it.
Do you have an old Motors Repair manual, or any other old automotive books that tend to cover more than just one manufacturer?
If you can't turn up anything I can try to search again.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
I had to replace the wire on my truck and as I recall, once you have opened the switch case, the bakelite block just pushes out from the back. The armored cable is just pressed into the back of the switch body and you have to remove that first. Then you can push the bakelite block out from the back where the wire exits. Perhaps a little WD40 will help loosen things up.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Originally Posted by Lightholder's Dad
...once you have opened the switch case, the bakelite block just pushes out from the back.
This is in fact correct. There are three divots on the metal housing (that I did not initially notice due to corrosion) to retain the bakelite block. But with some force, I was able to press the bakelite block past the divots without damage.
Thanks for the replies.
When I repaired mine, I used a Dremmel with a grinding wheel and carefully ground away the divots to get the bakelit block out, then after assembly filled the "slots" with a small amount of J B weld and sanded smooth.
That was a good idea. Sounds a lot less risky than forcing the bakelite block out.
