10 members (Greg_H, 1955 1 Series, Otto Skorzeny, TrknGMC, TooMany2count, KEVINSKI, Peggy M, Lostbuthaulinass, wilbur53, Wayne67vert), 130 guests, and 3 robots.
Topics128,142
Posts1,056,481
Members48,441
I have a 1950 3100 farm truck and I want to keep the weathered work truck appearance. The emblem on the front of the hood has no clips left. So my options are to get a new reproduction which will not match the rest of the truck or find a different method of attaching the old emblem to the hood. I could also get a new one and make it look old.
Anyone have a clever effective way to attach this old emblem to its old truck?
Jackie
If the new one uses the same clips order one use the new clips on the old emblem and throw the new emblem in a box under the bench.
Give me ambiguity
or give me something else
The clips are not removable.
We love pictures. Share your clips etc.
There's more ways to skin a cat.
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
That's what I thought....
I think I might give this a try..... http://www.gorillatough.com/heavy-duty-mounting-tape
The clips are completely gone..... I haven't bought a reproduction yet, that's my last resort.
That's definitely some "patina" on that emblem. wink
Nice straight truck. Good looking. thumbs_up
How about a few daubs of epoxy putty to remount the emblem?
JB Weld?
Big glob of silicone caulk. Easier then JB weld to remove if you change your mind.
That's a good idea too. Hold it in place with some duct tape while the silicone cures.
Here's your answer.
www.lord.com
No, it's not a religious site. It is actually automotive panel bonding adhesives. The very best. Check it out.
~~ Darcy
FootStomper
U
U Offline
Does a company owned by them have a subsidiary company with a separate LLC endeavor selling single tubes to certain distributors or something?
A specific link to a product might help share the product. I'm interested.
Brad
Wrench Fetcher, PhD
Originally the back had a provision for a stud/bolt
...pic...
Looks like yours are missing
I don't know if I would epoxy the emblem to the truck
You might be able to epoxy a bracket to the back for studs?
Or just epoxy 4 nuts to the back of the emblem, run studs and flange nuts on the inside.
I just reinstalled my original badge, mine was in a little bit better shape than yours , I was able to weld new studs on the old mounts
...pic...
...pic...
...pic...
...link...
I used 10/24 ...studs and flange nuts...
U
U Offline
DADS - can you post where you got the Auveco flange nuts & how much the pack you have pictured cost please?
And do you make all those trucks in the background?
Brad
Wrench Fetcher, PhD
I picked those up at carquest auto parts store
If you don't have a carquest try one of the others and I have seen them on eBay. Search for a pal nut
The models I purchase already built off eBay
This is the path I took....4 nuts J.B. Welded to the back of the emblem, 4 studs installed, 4 each of fender washers, lock washers and nuts (also a bit of paint) and now my very weathered badge will stay with my very weathered truck!
I will post pictures soon.
Thanks for all the advice!!
Jackie
pix
Repaired Hood Emblem
Pictures of badge repair attempt... I'm pretty confident it will hold up!
It will last as long as you own the truck. Good job!
Nice save
