0 members (),
88
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | I have a 1950 3100 farm truck and I want to keep the weathered work truck appearance. The emblem on the front of the hood has no clips left. So my options are to get a new reproduction which will not match the rest of the truck or find a different method of attaching the old emblem to the hood. I could also get a new one and make it look old. Anyone have a clever effective way to attach this old emblem to its old truck?
Jackie | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | If the new one uses the same clips order one use the new clips on the old emblem and throw the new emblem in a box under the bench.
| | | | | Joined: Mar 2010 Posts: 10,282 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,282 | The clips are not removable.
| | | | | Joined: Oct 2015 Posts: 338 Shop Shark | | Shop Shark Joined: Oct 2015 Posts: 338 | We love pictures. Share your clips etc. There's more ways to skin a cat. | | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | The clips are completely gone..... I haven't bought a reproduction yet, that's my last resort. | | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | | | | | | Joined: May 2015 Posts: 11,078 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,078 | That's definitely some "patina" on that emblem.  Nice straight truck. Good looking. How about a few daubs of epoxy putty to remount the emblem?
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 |
| | | | | Joined: Aug 2005 Posts: 277 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 277 | Big glob of silicone caulk. Easier then JB weld to remove if you change your mind. | | | | | Joined: May 2015 Posts: 11,078 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,078 | Big glob of silicone caulk. Easier then JB weld to remove if you change your mind. That's a good idea too. Hold it in place with some duct tape while the silicone cures.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2015 Posts: 338 Shop Shark | | Shop Shark Joined: Oct 2015 Posts: 338 | Here's your answer. www.lord.com No, it's not a religious site. It is actually automotive panel bonding adhesives. The very best. Check it out. | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Does a company owned by them have a subsidiary company with a separate LLC endeavor selling single tubes to certain distributors or something?
A specific link to a product might help share the product. I'm interested.
Brad
Wrench Fetcher, PhD | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Originally the back had a provision for a stud/bolt ...pic... Looks like yours are missing I don't know if I would epoxy the emblem to the truck You might be able to epoxy a bracket to the back for studs? Or just epoxy 4 nuts to the back of the emblem, run studs and flange nuts on the inside. I just reinstalled my original badge, mine was in a little bit better shape than yours , I was able to weld new studs on the old mounts ...pic... ...pic... ...pic... ...link... I used 10/24 ...studs and flange nuts... | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | DADS - can you post where you got the Auveco flange nuts & how much the pack you have pictured cost please?
And do you make all those trucks in the background?
Thanks Brad Wrench Fetcher, PhD | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I picked those up at carquest auto parts store
If you don't have a carquest try one of the others and I have seen them on eBay. Search for a pal nut
The models I purchase already built off eBay | | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | This is the path I took....4 nuts J.B. Welded to the back of the emblem, 4 studs installed, 4 each of fender washers, lock washers and nuts (also a bit of paint) and now my very weathered badge will stay with my very weathered truck! I will post pictures soon.
Thanks for all the advice!!
Jackie | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | Repaired Hood Emblem Pictures of badge repair attempt... I'm pretty confident it will hold up! | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | It will last as long as you own the truck. Good job!
