0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#113570 11/23/2003 6:24 PM
what is the best way to put the whindshild back window and corner glass in a 1950 5 window truck i have put windows in before but i want a few tips so i dont scratch the new paint
#113571 11/25/2003 12:33 AM
Have a helper that listens to you hold the glass from the other side so you can use both hands. If you need to use tools, use plastic ones.
Paint & Body Shop moderator
#113572 11/25/2003 12:54 AM
Does anyone know a product name for a lubricant that is used with glass rubber seals?
Thanks, Tim
#113573 11/25/2003 1:49 AM
Tim, I used liquid dish soap as a lubricant; any non-petroleum lube will work. I used the twine trick described in the shop manual. You will need an extra pair of hands to apply firm, even pressure while you pull the gasket into place.
edit: Sorry, Tim, you wanted a brand-name. K-Y. grin
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
