| | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 91 Member | | Member Joined: Oct 2003 Posts: 91 | what is the best way to put the whindshild back window and corner glass in a 1950 5 window truck i have put windows in before but i want a few tips so i dont scratch the new paint | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Have a helper that listens to you hold the glass from the other side so you can use both hands. If you need to use tools, use plastic ones.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Does anyone know a product name for a lubricant that is used with glass rubber seals?
Thanks, Tim | | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | Tim, I used liquid dish soap as a lubricant; any non-petroleum lube will work. I used the twine trick described in the shop manual. You will need an extra pair of hands to apply firm, even pressure while you pull the gasket into place. edit: Sorry, Tim, you wanted a brand-name. K-Y.  | | |
