1 members (Phak1),
186
Mod | | | Forums66 Topics128,110 Posts1,056,242 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | I took a couple photos of the new wheels I bought from etrailer.com. Dexstar Conventional Steel Wheel w/ +0.5" Offset - 16" x 6" Rim - 8 on 6-1/2 - Black https://goo.gl/photos/QK3mebxtsC9mJPNj6
1953 GMC 1-Ton Pickup with 350 and 700R4
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 |
| | | | | Joined: Jan 2015 Posts: 208 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 208 | Do you have any pictures of the wheels on the front?
| | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Not yet - without mounting a tire on it I'm not sure how it will look against the tie-rod. I'm trying to find some local used LT225/75R16 tires to try.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Chad,
Have you checked out the inside clearance with the tie-rod and steering arms in place? | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 |
| | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Tie-rod End Pic The Tires I chose are Crosswind L780 in LT225/75R16 size. Total diameter of tire is 28". This is a 10-ply tire with Load rating of "E". Section width is about 8.5". They also had this tire in LT215/85R16 which was about 30.5" diameter and slightly skinnier, at roughly 8.25" section width. That might be the good answer in terms of width, but I wanted to lower my truck a tad. So again my tires are Crosswind L780 in LT225/75R16 size. I have about 3/16" of space between the tie-rod and tire, which I'm leery about with any sidewall flex during driving. I'm going to add a 1/4" wheel spacer Jegs 1/4" Wheel Spacer to give me almost half an inch total between the tie-rod end and tire. The stock tires from the factory were roughly 30.5" diameter, so these are 2.5" less in diameter.
| | | | | Joined: Jul 2010 Posts: 10 New Guy | | New Guy Joined: Jul 2010 Posts: 10 | do these wheels work without the spacers???? WW | | | | | Joined: Jul 2010 Posts: 10 New Guy | | New Guy Joined: Jul 2010 Posts: 10 | | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Technically, yes. There was about 3/16" space between the tire and tierod end. But to me I felt that it wasnt enough if the tire flexed under cornering and I didnt want to take the chance. The 1/4" spacers have caused me no trouble. If you are leery, try 1/8" spacers. Also if you buy a skinnier tire it would be better. I believe Michilin makes an XP-Rib or something similar. My tire is a 10-ply Load E so it probably has minimal flex taking place.
| | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | The difference in price was roughly $250/ea for the Michilin tire vs about $100/ea for mine.
| | | | | Joined: Jul 2010 Posts: 10 New Guy | | New Guy Joined: Jul 2010 Posts: 10 | | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | A better tire spec might be 215/85R16 LT, also common - read, "readily available" - on current 1-ton working trucks hereabouts, and a marginally (1/2") higher profile.
1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Jul 2010 Posts: 10 New Guy | | New Guy Joined: Jul 2010 Posts: 10 | | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | Those rims are so beautiful, Chad. When are we gonna see 'em with hubcaps and beauty rings?
You can't just leave 'em all nekkid like that, can you?
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | On the wheel specs, was there an option on the offset? If there was, a 0 offset would have eliminated the need for a spacer.
Bill Burmeister | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | I havent tried to retrofit my baby moons yet. I dont think there was any options on the offset on these ones.
| | | | | Joined: Apr 2000 Posts: 28 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 28 | I use these wheels on my 51 3800 and have been for a couple years now, no problems. I run 215/85 16 Goodrich radials. I removed my hubcap clips by grinding them off the old wheels, drilled and tapped my new wheels and run original hubcaps. Perfectly satisfied with the setup. | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Phil can you explain further on how you installed your clips for your hubcaps?
| | | | | Joined: Feb 2008 Posts: 108 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 108 | http://www.ebay.com/itm/Hub-Cap-Clip-1939-1941-1946-Chevrolet-GMC-Truck-New-/322045642835?hash=item4afb6a8853:g:1LsAAOxyiklTlOwf&vxp=mtr I used these clips to attach my Task Force hubcaps to my 16 x 7 wheels. Use compass to find edge center of hubcap on wheel. Mark and drill four equal spots. Use self-tapping screws (2x per clip)to attach each clip (4x/wheel) to the wheel. You may have to alter the clip to secure the edge of hubcap. | | | | | Joined: Feb 2008 Posts: 108 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 108 | http://www.ebay.com/itm/Hub-Cap-Clip-1939-1941-1946-Chevrolet-GMC-Truck-New-/322045642835?hash=item4afb6a8853:g:1LsAAOxyiklTlOwf&vxp=mtr
