7 members (Otto Skorzeny, klhansen, Hotrod Lincoln, 3800GUY, farmallb, Rustnut, 1 invisible), 70 guests, and 4 robots.
Topics128,079
Posts1,056,301
Members48,441
#1134770 11/17/2015 6:48 PM
Bil
Offline
Moderated
Moderated
I have wiring diagram books and tech manual for my 1951 / 3100 Chevy truck but none have a wiring diagram for the heater. I have the switch under the dash and wires coming out of the blower motor with no idea what colors go where. Thank you!
Bil #1134804 11/17/2015 10:45 PM
Gas Pumper
Gas Pumper
Bil if this is a 6 volt system, its pretty easy. There are two wires on the heater, one of which is short and has a round terminal on it for grounding it to the heater case. The other simply goes to the switch. Then, the other terminal labeled BAT on the switch goes to your power source, usually the Ignition Switch on.
If its converted to 12 volts, there is a stepdown reducer in the mix. Then its wired in this order... Ignition Switch (positive) to the Reducer, Reducer to Switch, Switch to Fan Motor. Again, the negative side is grounded to the case. I spent a lot of time on this article that may help...
http://devestechnet.com/Home/Native12VUpgrade#heatersystem
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Bil #1134806 11/17/2015 10:51 PM
DAD550, Was the temperature control valve used on the 1950 3100? IF so, is it the same as the 1951? And do you know the make and model?
Deron
Deron
God made man to go by motives, and he will not go without them, any more than a boat without steam or a balloon without gas.
Bil #1135062 11/19/2015 5:21 PM
From what I have read on this forum heaters were installed later by dealer or shop.
I guess it would depend on what type of heater was installed in your truck
Mine is a Harrison fresh air heater and there was a ranco valve installed on the firewall.
I don't know if other brands or type used the valve.
If you post the type of heater you have maybe someone will be able to give you a better answer
Bil #1135072 11/19/2015 6:14 PM
What's the temp rating on the thermometer you all are using with your heaters? Is this a standard thermometer used in a 216 as is used on most Chevy engines or is it something special?
1951 Chevy 3100 1/2-Ton
"Piecing it Together - Blow by Blow"
Follow in the DITY
More photos in Flickr
1939 Chevy 3/4-Ton
In the Project Journals Forum
Bil #1135109 11/19/2015 10:31 PM
Gas Pumper
Gas Pumper
Thermometer? The Ranco Valves are the same up through at least 1953 and found on only the Harrison fresh air style heater. Are you talking about that or the engine Thermostat? I run a 180 degree thermostat, but I hear they also put 160's in some.
Deve
The Think Tank
Bil #1135114 11/19/2015 11:12 PM
What they called "160 degree" thermostats in 1950/51 (the stock/standard thermostat on small trucks), started opening at around 160 degrees, and were fully open at around 180 degrees.
Bil #1135207 11/20/2015 1:39 PM
Doh! Yes I meant thermostat. Is there a special one for the 216 or are they the same thing I'm familiar with for a SBC?
Follow in the DITY
1939 Chevy 3/4-Ton
Bil #1135227 11/20/2015 3:30 PM
Markiemark9,
The SBC thermostat fits perfectly in a 216. I recommend a "fail safe" thermostat. These thermostats "pop open" when they fail or get stuck, thus reducing the chance for a over heating situation.
Tim
1970 VW Beetle
Bil #1135433 11/21/2015 2:53 PM
Thanks!
Follow in the DITY
1939 Chevy 3/4-Ton
Bil #1135498 11/21/2015 8:39 PM
The Air-Flow heater was an R.P.O. In 1947 after that year it dropped to the accessories list for dealer or owner installation.
https://www.flickr.com/photos/advance-design_parts_co/17056970488/in/album-72157651718017649/
1947-early 48 leftovers, more in GMC than Chevys it seems? Two versions, deluxe had the defroster attachment as shown. This heater appears in the Salesman Data Book in 1947.
https://www.flickr.com/photos/advance-design_parts_co/9201965046/in/album-72157631868452754/
Two most common installs 47-52 (53-55 1st Series have internal door)
https://www.flickr.com/photos/advance-design_parts_co/8129448404/in/album-72157631868452754/
https://www.flickr.com/photos/advance-design_parts_co/8129470099/in/album-72157631868452754/
Bil #1135564 11/22/2015 4:17 AM
Gas Pumper
Gas Pumper
I am restoring a 47 and a 53 now. I wish they wouldn't have cheaped out on the 53 and decided on a simple Decal as opposed to the earlier badging. I do like the fresh air aspect of the 53 one. Harder to find cores for the 53 too. Thanks for the pics Brad. I always know where to go to get information on this stuff!
Deve
The Think Tank
Dads50,
Thanks. I have a Harrison also. Someone removed the valve and mounted the battery in that area. Do you know where I can find information, instructions, or pictures of the valve installation?
Deron
Bil #1135607 11/22/2015 2:23 PM
Bil #1136230 11/25/2015 5:09 AM
Tim,
Thanks. I picked up a copy of the 1950 accessory installation manual.
Deron
