3 members (BC59, dt235sd, Wooley), 124 guests, and 2 robots.
Topics128,162
Posts1,056,936
Members48,458
Since I now have an SM420 4-speed installed with my 302 GMC straight 6, I have a clearance problem with my stock floor board.. Instead of modifying it, and fabricating a new trans tunnel piece, does anyone out there make a floor kit for this model truck??
Have you looked at Bitchin products? They may carry something although not perfectly stock.
1951 1 Ton Completed
isn't there a different factory trans cover for the 3 and 4 spds? there is on the task force series - the 4 spd one has a hump, the 3spd one is flat - my 46 1.5T had a humped pan over the 4 spd, and I'd think the lighter trucks would be the same
Squeeze is right....as I understand it, the 3 and 4 speed floors are different.
I'll sell you mine....someone cut it in half with an air chisel. grin
46 in progress.. Yes, I am interested. I did not realize they had this for the 4 speeds. Can you email me some pictures to [email protected]
Steve
