Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (dt235sd, Sjm), 99 guests, and 2 robots.
Topics128,283
Posts1,058,505
Members48,490
Page 2 of 2 1 2
1 Offline
Accuair delivery come in. :-D
[URL=http://s1155.photobucket.com/user/sssingo/media/51%20Chevy%20SubURBAN/Screenshot2013-04-05at095306_zpsd24e12f1.png.html]pics[/url]
Your gaining on it Sssingo! Yep, it looks like Santa made a visit to your house. Keep the updates coming.
1 Offline
Well at long last the burb is back from media blasting. As is the norm it revealed a few extra needed repairs which have been done now
media blasting floor repairs
seat base repair
More floorpan action
1 Offline
1 Offline
1 Offline
We now have somne of the bone stock '51 Thistle Gray gunned ontothe firewall so's we could get the 350and700R4 back in. Just waiting for a more period looking cast Pertronix Ignitor dizzy and a front end bolt kit from Brothers before we can get it all bolted back together
Engine install
NJC Offline
Sir, Your 'Burb is coming along nicely. Please keep the pictures/progress reports flowing, and I'll try to do the same. Mine has just about all the outside metal that needed replacement done and now on to the limited mud, primer, and paint. Off, I now go to a second job to earn additional project $. Thanks Sssingo, V/R, Nick Cavallaro, Bel Air, MD
1 Offline
Time has passed but I am pleaseed to say the Burb is now back home.
Suburban in UK docks
1 Offline
1 Offline
The burb is in good company now back home
chevy vs ford
1 Offline
HELP NEEDED! On my clamshell lower door latches (at either side) I am trying to remove the central pin to repair a snapped of end. I have undone the screw but there is no sign of movement, how do I remove????
Is it just seized or is there something else I should be doing before removing it successfully???
Any help appreciated in advance
1 Offline
1 Offline
Lots gone on since last post. The burb has got even more deconstructed as I am replacing the ply floor inside the cab. The old one was still good butI';ve come this far it seemed mad not to do it.
Slammed
1 Offline
I've also been recreating a 1939 glass Trico washer bottle that I want to mount under the dash. These items are on ebay for anything from £680 so finding a suitable glass bottle of the same dimensions and making the accurate copy of the bracket and vacuum was the only option.
original
template
nearly finished
1 Offline
Got some interior body colour on albeit only my glovebox inner glovebox painted
1 Offline
Yes I'm afriad the car is going to be an ASBO lowscraper
been putting the final touches to my scrape bar loaded with Titanium titanium bridge bar
in situ
There is nothing wrong with ASBO - you are not hurting anyone. It is your truck.
Thanks for posting progress reports.
1 Offline
Glad you agree Tim
1 Offline
Rear Suburban floor upgrade
After much deliberation although my ply floor has survived 60+ years I thought now was to time to replace it before fully rebuilding the ride.
I opted for a two layer replacement that I could hide some of the bolts that I didn't want to see within the two layers.
First layer is Birch ply which comes with twice as many ply layers as the original and much denser, with the decorative marine Iroko deck skin applied over the top.
Tools for the job
1 Offline
Suburban rear deck replaced
Decided to mount the #accuair airride tank on the step notch cover with the valves and make something out of it just in case anything goes wrong. It was originally mounted underneath but even in my garage with trolley jacks and axle stands it was hard to get to let alone at the side of a raining motorway at night
1 Offline
1 Offline
1 Offline
Making a start on the Airride hardline
My dad was a hydraulics engineer so feel like the pressure is on to create good bends from the 3/8 stainless as this stuff costs too much to waste any with mistakes.
1 Offline
Polished or raw stainless???
what do you think?
1 Offline
1 Offline
My favourite part of the Clamshell burb is the hinged taillight housing. Take that and add a modified B-31 backuplight and now I really love it.
I think this is the original style ...shed some light on that (excuse the pun)
Backup light with Magnifier lens
Nice work, Sssingo
B-31 was a commonly used backup light.
1 Offline
Nice work, Sssingo
Thanks Tim. Too dark and cold to get much donw at this time of the year tho.
1 Offline
Sorry not visited for a while. Just noticed the attachment manager function for attaching pics which will make it much easier to post progress.
moving out of my old leaking rental garage. Lots of space but no power and wet
1 Offline
To further back up my theme and act as a homage to my dear old Grandad I have mounted my rod carrier with the rod he made for me back as a child.
1singo #1343473 01/24/2020 8:49 PM
1 Offline
Repairing seats that came with my burb and restoring ones I was ripped off shipping over I found a spring manufacturer that made the same spring in UK. Then blasted and re painted preior to upholstery
blasting of old springs and frame
springs and frame in primer / paint
final colour and detail
mock up rear gunner seat
rear gunner seat
1 Offline
Seat in place
seat in place
1 Offline
I may have just hit on a TOP HACK for installing #chevysuburban side windows...
CAPTIONS TO STEP-BY-STEP IMAGES
1:Starting at the front end of each window take note of where the two channel fixing holes sit together.
2:Even if you are refitting existing glass I think for the sake of a few£$€s it is worth transferring the shape onto some 5mm ply and using them as templates. Jim carter sell paper templates that are very accurate as long as you cut along the inside edge of their marks. I transferred the location of these two holes onto a 5mm glass template.
3:I trimmed the edge square as it was all kinds of wrong when I received it from parts supplier
4: Starting half way between the two marks grip your channel over the edge of your template
5: The channel will want to kink especially on the tight radius
1 Offline
STEP6: At first I spent hours removing then straightening the kinks with pliers
STEP7: BUT HERES THE HACK! because you are using a cheap bit of work to form around rather than glass you can tap the kinks flat with a hammer. For a clean channel cover with thin cloth first
STEP8: First corners done and holding shape
STEP9:Trial fit to between those first two mounting holes
STEP10: Now it gets trickier. You may need a few soft teeth clamps if working alone
1 Offline
STEP 11: Mark the start of the rear radius on you sliding glass template
STEP12: Foreman approval
STEP13: Trial fit with fixed glass rubber filler in place
STEP14: Not a bad curve. Would love to hear any other ways of shaving hours from this install with your top tips but thought I’d share this one
Page 2 of 2 1 2
