| | | Forums66 Topics128,062 Posts1,055,845 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 96 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 96 | Good Morning! I'm in Germany and thinking about putting a V-8 into my 55 series II. The stovebolt is running fine but I've found a complete 283 with a 4 speed transmission out of a 59 pickup. I'm OK on the engine side of things but the tranny has me stumped. In the pictures sent to me, it's not a top loader, like my 55. It has a side cover with shifter levers like the Borg-Warner T-10 in my old corvette. Did 59 pick ups with four speeds have a column shifter? The guy who has it is out of town til mid December so he can't help me. Thanks
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy sepp, the four speeds in the trucks had a single shifter in the center of the top cover, I think the four speed with the 283 is from a car as you suspected and probably used a floor shifter, hope that helps. | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Hy sepp, the four speeds in the trucks had a single shifter in the center of the top cover, I think the four speed with the 283 is from a car as you suspected and probably used a floor shifter, hope that helps. That would be my guess also.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Are you sure that it is a 4 speed? GM used a T89 Borg Warner as a heavy duty option. It is a very tough transmission, but it is only a 3 speed. | | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | How many shift levers does the transmission have? A 4 speed will have 3, a 1-2, a 3-4, and a separate lever for reverse. Jerry
