4 members (68ironhead, Hanks custodian, Gray_Ghost, Ponchogl), 51 guests, and 3 robots.
Topics128,026
Posts1,055,404
Members48,422
#1134394 11/15/2015 2:14 PM
Hey all, I was wondering if the '59 had the foot starter as did the '58. I'm seeing trucks for sale without it. Is it a common modification to remove it?
Ribside #1134400 11/15/2015 2:31 PM
1959 was the last year that had a foot-starter as standard equipment on manual transmission trucks.
http://chevy.oldcarmanualproject.com/chevyresto/59ted21.htm
In 1960, all 235/261 engines/transmissions came with solenoid starter.
https://dl.dropboxusercontent.com/u/30524403/1960-Chevrolet-Truck%20235%20261%20starters.pdf
Ribside #1134402 11/15/2015 2:35 PM
Well, I just found a manual online and this is what it says:
"Starter Control. Ignition key starting is provided on Forward Control models, automatic transmission equipped models and all V-8 models. A starter pedal located near the center of the toe board to the right of the accelerator pedal is used on other truck models."
So there you go.
Ribside #1134412 11/15/2015 4:01 PM
yes they did still have foot starters, as my apache has one. smile
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Ribside #1138862 12/11/2015 9:58 AM
The 6 cyl equipped 1959 truck used the foot stomp stater method with a 2 position ignition switch (on/off). The V8 trucks did not use that method and they used a 3 position ignition switch (off/on/start).
1959 3100 Apache Fleetside
