| | | Forums66 Topics128,154 Posts1,056,838 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 28 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 28 | I got this truck over the summer, started working on it, runs pretty good, still working on brakes, interior, windows (anyone have a downloadable rear window template?) and hunting a 9ft bed. But mostly I've been taking photos of it. Here's a link to my photobucket image folder.... http://s215.photobucket.com/user/smashsquatch/1946%20Chevy%201point5%20ton/story | | | | | Joined: Feb 2012 Posts: 28 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 28 | Well, I found the proper piece of glass, trim and an install tool on Jim Carter site. | | | | | Joined: Dec 2007 Posts: 171 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 171 | You have a nice looking project. Do you have a set of wheels for the truck? I have similar truck but an early '47 GMC short wheelbase dump truck. I have the 8 vent hole rims, like what you have on the back of your truck, and was luck to locate what I needed for a full set. Do you need any wheels? Do you have the PTO for your transmission? Al | | | | | Joined: Feb 2012 Posts: 28 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 28 | Thanks. I have one extra (the 8 vent you mentioned) The others are all 5 vent (I have 2 fronts and 4 for the rear) although I only plan on running 2 rear, I'm keeping the other 2 in case I want to set it up as a dually again. The 8 vent rear belongs to the guy I bought it from and I told him I'd give it back when I get my tires mounted to the other rims. I AM in need of some tires all the way around. No PTO unfortunately. I'd like to set up a PTO winch on it.
| | | | | Joined: Mar 2004 Posts: 6,228 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,228 | Not sure what trans you have, but if it's an SM420, I have a PTO...PM me about it if interested. Mike B  | | | | | Joined: Feb 2012 Posts: 28 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 28 | thanks, I sent an email of interest. | | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Sweet lookin'ld rig. Is that a stainless grill? | | |
