| | | Forums66 Topics128,182 Posts1,057,260 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 60 'Bolter | | 'Bolter Joined: May 2012 Posts: 60 | Does anyone know where I can purchase a wiring diagram for my 59 3600 on something bigger than what is in my repair manual? I would love to find one on an 11"x 17" sheet of paper. It seems that the older I get the closer those lines get together. Thanks, Rick -
Proud of my taskforce! 1959 3600 long-bed. the ultimate work truck!
Rick Restivo Valley Center, CA.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Check eBay item #371482323371 11" x 17" as required, heck it is even laminated! | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I use a magnifying glass to read those. Then sketch my own wiring diagram for the area I'm working on. Not that many wires. You could draw the whole thing in an hour or less on some printer paper (two of those together is 11 x 17) or use an online drawing app. But then again, I used to do that for a living.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2004 Posts: 29,880 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,880 | One of the business form places like Staples or Office Depot should be able to do a blowup of the service manual page and print it for you into a larger format. I've had pretty good luck using the Control and + buttons on the computer to enlarge a scanned print if it doesn't pixel out in the process. Jerry
| | | | | Joined: Mar 2010 Posts: 10,309 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,309 | I can magnify it with my printer. My problem is, I can't read Elecronese. Carl
| | | | | Joined: May 2012 Posts: 60 'Bolter | | 'Bolter Joined: May 2012 Posts: 60 | Thanks for the great feedback. I like the idea of taking the page out of the manual to Office Depot and blowing it up. My book is so old, and the pages have all yellowed. If it doesn't work I'll definitely check out E-bay. Heck. E-bay has everything... I should have thought of that myself.
| | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | I took a copy of the wiring diagram for my truck from one of the ones suggested here on Stovebolt and had it blown up at the local blueprint shop - $3.00 Canadian - which is like 10 cents American these days. | | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | I used one that I found on line that was color coded for a 55 2nd. series. I took it to office depot and had it done on a 1ft by 2 ft. sheet. Then I had it laminated so I could take it under the truck while chasing down gremlins. Best part it can get wet or oily and just wipe it off stand it back up and keep working. | | |
