| | | Forums66 Topics128,160 Posts1,057,054 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2015 Posts: 17 'Bolter | | 'Bolter Joined: Mar 2015 Posts: 17 | I put 1973 GMC truck front end assembly under my 1965 Chevy truck.Has anyone else done this and how did it work out? | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Every place that I've read about these conversions says it works great. You are now converted to 5 lug and disc brakes, right? You should use everything from the 1973. gear box, pitman arm, crosslink, spindles. | | | | | Joined: Dec 2015 Posts: 491 Unconventional Thinker | | Unconventional Thinker Joined: Dec 2015 Posts: 491 | I haven't done the whole assembly, but I have done the conversion using the modern spindles, but using my old control arms. I've read that using the whole assembly works too. Mine is 8 lug, and I didn't know where to source a 3/4 ton front end, so I had to buy kits. I wish I'd known then what I know now, I could have save a ton of money.
Shane
Shane's Toys... 2007 Forester XT Limited (2nd Owner) 1991 Cherokee Laredo (2nd Owner) 1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner) 1965 Chevy 3/4 Ton Fleetside (3rd Owner)
| | | | | Joined: Sep 2015 Posts: 8 New Guy | | New Guy Joined: Sep 2015 Posts: 8 | I did it and worked well. You just have to change out your tie rods and ball joints for whatever year spindles you have and I took the steering linkage from the donor otherwise you have to use some tie rod adjuster sleeves. They are $50 bucks | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | On my 64' I used an 87' model, and it was a breeze. I now have disc brakes, power steering, and parts that are 20+ newer. Even managed to score the sway bar. | | | | | Joined: Sep 2015 Posts: 8 New Guy | | New Guy Joined: Sep 2015 Posts: 8 | | | | | | Joined: Feb 2010 Posts: 82 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Feb 2010 Posts: 82 | I did a 91 Suburban suspension/cross member swap on my 66 Suburban and it turned out great. | | |
