2 members (BC59, Gray_Ghost), 154 guests, and 1 robot.
Topics128,079
Posts1,056,058
Members48,433
#1132310 11/01/2015 4:12 AM
Can someone tell me if those 3 engines are the same length.......depending on the answer I'll be posting in another forum.
This would be from the back of the engine to the front of the block where the water pump bolts on.
Thanks for any clarification/help.
Last edited by Achipmunk; 11/02/2015 3:35 AM. Reason: clarification-measure to frront of block.
The engines are all the same length.
My Blog
Dave, your right. I edited it to make it a little more clear.
I'm going to start another post, about my problem, since I'm putting the 261 in a car. Please read and comment if you will.....Or Deve, or anyone else that might help.
Alvin,
What year car?
Have you considered using Dave's plate with a water pump appropriate for your car?
may have been there done that. What yr what car what forum
A fellow bolter has answered my questions and sent parts....water pump, adapter, fan, harmonic balancer. The other related thread I started was here?
https://www.stovebolt.com/ubbthreads/ubbthreads.php/forums/19/1/Modern_GM_and_Non-GM.html
