9 members (TUTS 59, Millenimech, cmayna, Hanks custodian, Otto Skorzeny, Oswald, Cosmo, Bill Hanlon, gswbbc),
89
Mod | | | Forums66 Topics128,042 Posts1,055,522 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | Last night I noticed my light switch was real stiff, tonight I thought I was going to have to put my feet on the dash and use both hands to get it to the headlight position. Is there something I can use as a lube or do I bite the bullet and replace it? John | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Year?
Have you ever taken out the light switch?
| | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | Sorry Tim, its a 51. I haven't taken it out yet. I posted this as soon as I got home so I didn't forget. The switch was stiff before, but I haven't needed the lights since last spring. John | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | The switch can be taken apart, but can be tricky not to loose small pieces. I took apart a few and cleaned real good and used dielectric grease to put them back together. They seem to work real slick. | | | | | Joined: Jun 2005 Posts: 1,001 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,001 | Wouldn't spraying some WD-40 (or the like) on and down the shaft be worth the effort before disassembling it?
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes, I've used WD-40 to clean and lube volume controls on old radios many times.
dg
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Three votes on the WD-40. | | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | Thanks for the replies. I used WD-40 on on/off switches, I'm gonna give it a try. John | | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | Gave it the WD-40 treatment this morning, tonight when I got in to come home the switch actually worked! Still a little stiff, I think I'll give it a shot of contact cleaner and WD this weekend and see what happens. After reading about some of the replacement switches I'm not looking forward to replacing it. John | | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | Another vote to take it apart and clean it. That switch will last 50 more years with a good cleaning and some fresh dielectric grease. Glad you're not pitching it for a new repop! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | dielectric grease is non-conductive it might be OK
I use contact cleaner (non-silicone and non-dielectric) and maybe WD-40 (non-silicone version - they now sell a silicone spray, which might cause future contamination when painting). | | |
