5 members (rfs56trk, 55shaker, DadsFirstPickup, JoergK., 1 invisible), 324 guests, and 3 robots.
Topics128,152
Posts1,057,011
Members48,460
Does anyone have or know where I can see pictures of a 41-46 1/2 ton PU (assembled without cab) master cylinder/pedal setup mounted to the bell housing in the frame? I bought a 42-46 shop manual, but the picts are too dark.
1946 1/2 ton - 1962 "261"
1953 1/2 ton 5-window - "235"
1955 1/2 ton - 55 "265" Corvette motor
1959 1/2 ton Fleetside - "283"
Thanks for the picture, now I need to figure out what to do if I use a T-5 Tranny.
Anyone have pictures of that?
Mark
People have reported success with only supporting the master cylinder mount by the bellhousing, but I would suggest making a bracket that fastens to one of the rear transmission bolts and to the rear master cylinder bolt to provide additional support to the mount.
