| | | Forums66 Topics128,180 Posts1,057,067 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 101 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 101 | Does anyone have or know where I can see pictures of a 41-46 1/2 ton PU (assembled without cab) master cylinder/pedal setup mounted to the bell housing in the frame? I bought a 42-46 shop manual, but the picts are too dark.
1946 1/2 ton - 1962 "261" 1953 1/2 ton 5-window - "235" 1955 1/2 ton - 55 "265" Corvette motor 1959 1/2 ton Fleetside - "283"
| | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | | | | | | Joined: Jan 2000 Posts: 101 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 101 | Thanks for the picture, now I need to figure out what to do if I use a T-5 Tranny.
Anyone have pictures of that?
Mark
| | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | Picture People have reported success with only supporting the master cylinder mount by the bellhousing, but I would suggest making a bracket that fastens to one of the rear transmission bolts and to the rear master cylinder bolt to provide additional support to the mount. | | |
