1 members (baldeagle), 46 guests, and 4 robots.
Topics128,037
Posts1,055,466
Members48,424
#1132478 11/02/2015 3:46 AM
Last night I noticed my light switch was real stiff, tonight I thought I was going to have to put my feet on the dash and use both hands to get it to the headlight position. Is there something I can use as a lube or do I bite the bullet and replace it? John
Year?
Have you ever taken out the light switch?
Sorry Tim, its a 51. I haven't taken it out yet. I posted this as soon as I got home so I didn't forget. The switch was stiff before, but I haven't needed the lights since last spring. John
The switch can be taken apart, but can be tricky not to loose small pieces. I took apart a few and cleaned real good and used dielectric grease to put them back together. They seem to work real slick.
V
VEW Offline
V Offline
Wouldn't spraying some WD-40 (or the like) on and down the shaft be worth the effort before disassembling it?
~ Victor
1957 3100 - moved on
Yes, I've used WD-40 to clean and lube volume controls on old radios many times.
dg
Denny G
Sandwich, IL
Three votes on the WD-40.
Thanks for the replies. I used WD-40 on on/off switches, I'm gonna give it a try. John
Gave it the WD-40 treatment this morning, tonight when I got in to come home the switch actually worked! Still a little stiff, I think I'll give it a shot of contact cleaner and WD this weekend and see what happens. After reading about some of the replacement switches I'm not looking forward to replacing it. John
Another vote to take it apart and clean it. That switch will last 50 more years with a good cleaning and some fresh dielectric grease. Glad you're not pitching it for a new repop!
dielectric grease is non-conductive
it might be OK
I use contact cleaner (non-silicone and non-dielectric) and maybe WD-40 (non-silicone version - they now sell a silicone spray, which might cause future contamination when painting).
