2 members (Otto Skorzeny, 1 invisible),
269
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,079 Posts1,056,058 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Can someone tell me if those 3 engines are the same length.......depending on the answer I'll be posting in another forum. This would be from the back of the engine to the front of the block where the water pump bolts on.
Thanks for any clarification/help.
Last edited by Achipmunk; 11/02/2015 3:35 AM. Reason: clarification-measure to frront of block.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The engines are all the same length.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Dave, your right. I edited it to make it a little more clear. I'm going to start another post, about my problem, since I'm putting the 261 in a car. Please read and comment if you will.....Or Deve, or anyone else that might help. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Alvin,
What year car?
Have you considered using Dave's plate with a water pump appropriate for your car? | | | | | Joined: Sep 2010 Posts: 122 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 122 | may have been there done that. What yr what car what forum | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | A fellow bolter has answered my questions and sent parts....water pump, adapter, fan, harmonic balancer. The other related thread I started was here? https://www.stovebolt.com/ubbthreads/ubbthreads.php/forums/19/1/Modern_GM_and_Non-GM.html
