| | | Forums66 Topics128,074 Posts1,055,910 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2014 Posts: 62 'Bolter | | 'Bolter Joined: Apr 2014 Posts: 62 | I have a 61 Apache and I replaced the points with the metronix electronic unit. I must have knocked the timing out as the motor now pings. I found there is no timing tab on the front of the motor. What do I do to re-set the timing to eliminate the pinging?
Thanks john
1961 Long Stepside Apache 10, original 235, 4 speed and 3:90 posi totally stock (owned 12 years) 1966 Chevelle (owned 53 years) | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | John, Probably a Pertronix unit? Nonetheless, the timing mark/needle can be viewed on the the forward face of the clutch housing above the starter. You could also just loosen and rotate the distributer in either/both directions, little by little until the ping disappears.. Or, buy a vacuum gauge and use this technique. | | | | | Joined: Apr 2014 Posts: 62 'Bolter | | 'Bolter Joined: Apr 2014 Posts: 62 | Thanks all for the advice,
