1 members (Forty9), 64 guests, and 2 robots.
Topics128,043
Posts1,055,610
#1132010 10/30/2015 4:12 AM
I have a 61 Apache and I replaced the points with the metronix electronic unit. I must have knocked the timing out as the motor now pings. I found there is no timing tab on the front of the motor. What do I do to re-set the timing to eliminate the pinging?
john
1961 Long Stepside Apache 10, original 235, 4 speed and 3:90 posi totally stock (owned 12 years)
1966 Chevelle (owned 53 years)
jb66ss396 #1132052 10/30/2015 12:58 PM
John,
Probably a Pertronix unit?
Nonetheless, the timing mark/needle can be viewed on the the forward face of the clutch housing above the starter.
You could also just loosen and rotate the distributer in either/both directions, little by little until the ping disappears..
Or, buy a vacuum gauge and use this technique.
Thanks all for the advice,
