0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | On a 56,235 does the foward(closest to front) line go to the inlet(top) fitting on the filter housing? and the rear line to the bottom? This is facing the left side of the engine. If i took pictures BEFORE i took it apart i would not need help now. Thanks | | | | | Joined: Jan 2015 Posts: 192 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 192 | On my '56 235 the center bottom of the filter went to the rear of the engine. I'm not saying it's the right way, but that is the way it was when I got it. I assume it is the right way tho. | | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | Thanks lemmm117,i thought that was correct. | | | | | Joined: Jan 2015 Posts: 192 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 192 | Oh, wait wait wait. I was mistaken. Mine has the center bottom of filter goin to the front oil hole on the engine. I'm sorry. | | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | It will work either way, but the most common flex line arrangement is to plumb the line from the oil pressure port (upper position near the rear of the block) to the outside center of the filter housing, and plumb the bottom of the filter housing to the forward port near the oil pan rail. There is a 1/16" hole about halfway up the center post of the filter housing that meters the oil flow through the filter. The conventional direction of flow is for the unfiltered oil to pass through the filter media from the outside, and return to the oil pan through the center tube and the bottom port of the housing. Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Tim, does that link for the '54 also true for the '56 261 engine? Just checking my "math". | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I do not know, Alvin, but I would guess "yes".
Pre '68 Dave (and others) would (might) know for sure. | | |
