1 members (fonz8261),
201
Mod | | | Forums66 Topics128,074 Posts1,055,999 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 122 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 122 | The gas pedal return spring keeps pulling the dash throttle knob back closed when I pull it out. Had carb rebuilt, new dash throttle control installed and got somethin wrong. Worked perfect before I messed with it. Go ahead, hit me, hurt me, I deserve it!!!! Rochester B 1 bbl carb w/manual choke on a 261. Carb linkage comes up from the bell crank and turns 90 into the carb throttle lever hole. A pic or 2 might be worth a thousand words. Send via 231-638-2429, or [email protected] whichever is convenient Thanks much | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Friction inside the dash end of the throttle cable is what keeps the throttle cable from being retracted by the throttle return spring.
I think you might need to carefully crimp the "tube" at the dash end of the new throttle cable "housing".
However, wait to hear from other people before doing any crimping. | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | How much foot effort does it take to step on he gas? You might have too strong of a spring.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "Worked perfect before I messed with it."
Did you change the throttle return spring? | | | | | Joined: May 2009 Posts: 85 'Bolter | | 'Bolter Joined: May 2009 Posts: 85 | Sent u a couple pictures, only ones I have in the shop are Carters, no connection between choke and throttle but yours may have a stepped plate to open the throttle plate a little when the choke is on but I don't think it should be connected to the return spring. I may be thinking about an automatic choke though. Hope I didn't confuse you more, I may have confused myself though!
1949 3100
| | | | | Joined: Sep 2010 Posts: 122 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 122 | I think tclederman hit the nail on the head in suggesting crimping the tube to develope enough friction to compensate for spring tension. thanks to all respondents and a special one to tclederman | | | | | Joined: Aug 2015 Posts: 86 'Bolter | | 'Bolter Joined: Aug 2015 Posts: 86 | Would you be willing to share a picture on here of honors connected to the carb? | | | | | Joined: Jan 2014 Posts: 86 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 86 | . A pic or 2 might be worth a thousand words. Send via 231-638-2429. Choke and throttle controls schematic texted. Bob
1959 Chevy Apache Short Bed Step Side 1967 Cadillac DeVille Convertible 1967 Pontiac Firebird Convertible
