3 members (Jon G, Hanks custodian, Bill Hanlon), 143 guests, and 10 robots.
Topics128,078
Posts1,056,027
Members48,433
#1130068 10/18/2015 7:46 PM
Does anyone have a source for the 4 hood emblem clips for a 1951 Chevy 6400. The emblem that I have is missing all 4. I suppose I could mount 4 bolts to it and pass those through the hood and put nuts on them but wanted to see if the clips are available. Thanks.
They are not weld able so I suggest not trying to modify them by weld or glue. They are held on with spring clips, take the emblem to your local Ace hardware as they sell them. Another alternative is pan nuts, they cut their own threads and held many Chevrolet emblems on a bit after the AD era for several model years. Pan nuts are also available at Ace, Home Depot and Auto Zone.
I ran a die down on mine. A nut and lock washer worked well. The spring type clips are available from hardware stores so, if you want use them. The nut means you can remove if needed. The clips are a PITA to get off.
Steve H
Is he asking about the front or side
The front emblem is what I need the clips for.
WE NEED PICS!
(He exclaimed without rude, nor overbearing intent.)
Carl
Originally Posted by DADS50
Just to clean up this thread
I went to my local carquest and asked for the above nuts
Of course they refer to them as something totally different, and at first didn't know what I was talking about
But the did have them on the rack.
4 bucks
...They call them washer lock nuts at carquest...
...another pic. SKU number...
Nice not to have to pay shipping.
Now, on to trying to save the original emblem on my Dads old truck.
Thanks for the responses...guess I should of just checked the flaps in the first place (good call Bill) At least the info is out there now for the next guy
...pic...
I think that the OP is not looking for nuts, but rather, the clips and threaded portion . (?)
I am too. The originals are rusted completely away.
Carl
52 Carl is correct. I am looking for the clips and the threaded posts (4 of each) which are attached to the backside of the front emblem for mounting to the hood. Mine are totally gone so I don't have any to post in a picture.
If just the studs are broken you might be able to make a repair
...pic...
If everything is gone your out of luck,
the repos are pretty good
The problem is that it doesn't seem that anyone makes a repro for the larger trucks. The emblem on them is a larger size as far as depth compared to the ones used on the smaller trucks due to the difference in the hood size.
Without the threaded receiver for the studs it will be tough to fab something up
I was lucky. Just the studs were broken off
I was able to weld new studs on mine
Picked up some 10/24 studs from the hardware store
And the nuts with the flange.
Not sure how you would tackle this
Maybe a 10/24 coupling nut but you will have to figure a way to attach them.
Anyone have a idea?
