2 members (VicZ, doyle1950),
143
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 30 | Does anyone have a source for the 4 hood emblem clips for a 1951 Chevy 6400. The emblem that I have is missing all 4. I suppose I could mount 4 bolts to it and pass those through the hood and put nuts on them but wanted to see if the clips are available. Thanks. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | They are not weld able so I suggest not trying to modify them by weld or glue. They are held on with spring clips, take the emblem to your local Ace hardware as they sell them. Another alternative is pan nuts, they cut their own threads and held many Chevrolet emblems on a bit after the AD era for several model years. Pan nuts are also available at Ace, Home Depot and Auto Zone. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | I ran a die down on mine. A nut and lock washer worked well. The spring type clips are available from hardware stores so, if you want use them. The nut means you can remove if needed. The clips are a PITA to get off.
Steve H
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Is he asking about the front or side | | | | | Joined: Feb 2015 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 30 | The front emblem is what I need the clips for. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | WE NEED PICS! (He exclaimed without rude, nor overbearing intent.) Carl
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Just to clean up this thread I went to my local carquest and asked for the above nuts Of course they refer to them as something totally different, and at first didn't know what I was talking about But the did have them on the rack. 4 bucks ...They call them washer lock nuts at carquest... ...another pic. SKU number... Nice not to have to pay shipping. Now, on to trying to save the original emblem on my Dads old truck. Thanks for the responses...guess I should of just checked the flaps in the first place (good call Bill) At least the info is out there now for the next guy ...pic... | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | I think that the OP is not looking for nuts, but rather, the clips and threaded portion . (?) I am too. The originals are rusted completely away. Carl
| | | | | Joined: Feb 2015 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 30 | 52 Carl is correct. I am looking for the clips and the threaded posts (4 of each) which are attached to the backside of the front emblem for mounting to the hood. Mine are totally gone so I don't have any to post in a picture. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | If just the studs are broken you might be able to make a repair ...pic... If everything is gone your out of luck, the repos are pretty good | | | | | Joined: Feb 2015 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 30 | The problem is that it doesn't seem that anyone makes a repro for the larger trucks. The emblem on them is a larger size as far as depth compared to the ones used on the smaller trucks due to the difference in the hood size. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Without the threaded receiver for the studs it will be tough to fab something up
I was lucky. Just the studs were broken off
I was able to weld new studs on mine Picked up some 10/24 studs from the hardware store And the nuts with the flange.
Not sure how you would tackle this Maybe a 10/24 coupling nut but you will have to figure a way to attach them.
Anyone have a idea? | | |
