2 members (gswbbc, wilbur53), 139 guests, and 3 robots.
Topics128,035
Posts1,055,446
Members48,422
#1130711 10/22/2015 2:52 AM
I've had my'53 3100 about a year & I haven't driven much at night but I think my headlights need to be adjusted. They appear to be aiming high (low beams) and oncoming drivers occasionally flash their lights. They appear to be straight ahead when trained on my garage wall, however, so does anyone know how can I accurately adjust them? Thanks.
~Denny
1953 Chevy 3100
w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter
1998 Chevy Suburban 350 ci awd/4wd
DJM, check with some local body shops. I have one here that I've been friends with for several years and they adjusted the ones on my panel in about 15 minutes. (I had the trim rings off) Fee should be minimal. Ask around.
Or....get yourself a couple big sheets of cardboard and layout
the pattern shown in the link Tim posted.
http://www.pbase.com/dennygraham/image/138714064/original
dg
Denny G
Sandwich, IL
Thanks for posting that again, Denny
I remember when you posted that same information a few years ago. I went right out to the garage and set up a crude alignment "chart".
Excellent info and exactly what I needed. Thanks!
~Denny
1953 Chevy 3100
Would you have a chart for aiming headlights on a "59?
1959 3100 Apache Fleetside
Is it in your Shop Manual?
Ex Hall Monitor
Ex Hall Monitor
When adjusting headlights that have a spring component, as most old Chevys do, and you need to loosen one of the screw adjusters, allowing the spring to move the bulb, go past the desired aim point then tighten the screw against the spring to the desired aim point. If that sounds confusing PM me and I'll go into more detail.
It helps to pull into place straight. Did this last summer with a tape measure and my friends garage door. Simple but, I got to do it again cause I had pulled in crooked to the door. Fine way to get experience any way. Makes driving after dark more fun and less worry.
Steve H
