3 members (Bill Hanlon, Patina 54, Guitplayer), 88 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#1129670 10/15/2015 10:04 PM
Hi. I'm removing the engine from my 48' 1 ton and I was wondering if I should mount it from the bell housing to the stand or right to the engine? And what size bolts fit those spots? I know they need to be grade 8, just unsure of the size.
Bryce S. #1129676 10/15/2015 10:43 PM
Right to the engine. Those 6 cylinder are pretty long to begin with, and heavy on top of it. You don't want to add any more leverage on the stand than necessary. IIRC, as it's been a while since I had mine out, they're 1/2-13.
Bill Burmeister
Bryce S. #1129677 10/15/2015 10:45 PM
Ok. Thanks!
Bryce S. #1129756 10/16/2015 1:14 PM
Also, do I just bolt them into where the bell housing bolts into or somewhere different?
Bryce S. #1129823 10/16/2015 11:30 PM
Same as the bellhousing.
Bill Burmeister
Bryce S. #1129824 10/16/2015 11:34 PM
I like to use a couple of pieces of 1/4" X 2" flat stock to extend the upper mounting points about 3" on each side. It makes the engine stand a lot easier to set up and allows you to locate the crankshaft flange well below the pivot point of the stand to make turning the engine over for work on the crankshaft safer.
Bryce S. #1129838 10/17/2015 1:56 AM
Ok. I am having troubles with the engine removal. I have the front motor mounts all disconnected, and I can lift the front up, but the rear wont budge. I have the motor mount bolts out, and I could only find 2 bolts to the transmission. Should there be 4? I looked all over and I can not find the other 2 bolts.
Bryce S. #1129841 10/17/2015 2:02 AM
Bottom bolt heads are inside bellhousing.
Bryce S. #1129846 10/17/2015 2:23 AM
I'm sorry, this is my first time working on a six. Can you access that by just crawling under the truck or do I have to remove something?
Bryce S. #1129852 10/17/2015 3:07 AM
if you have the metal flywheel inspection cover off you should be able to access the bolts. Take your time, get a good light and you'll be just fine.
Achipmunk #1129870 10/17/2015 6:02 AM
May need to dig around with a scraper to find the bolt heads!
BC
1960 C60 pasture art
Bryce S. #1129892 10/17/2015 1:27 PM
Once you have the tin cover off that's under the flywheel the bolts will be exactly in line with the bottom transmission mounting ears; in fact you can see the ends of the bolts in the trans ears from the outside. There shouldn't be much scraping to do but the bolt heads are slightly recessed and take a 3/4" wrench. A wrench with a dog leg in it or a SHORT socket and breaker bar works better. There isn't room for a ratchet. When removing the tin cover the two hard to get to bolts next to the oil pan just need to be loosened as the holes are slotted. Many of the crossmembers have an access hole for a screwdriver to pass through for loosening the bolts but are often caked shut with crud.
Evan
Bryce S. #1129901 10/17/2015 3:44 PM
A sneaky trick we used to use was to find an old 3/4" socket and weld it to a piece of 1/4" thick flat bar about 18" long to access those lower transmission bolts. Just the right offset, and plenty of torque to tighten/loosen the bolts.
Bryce S. #1130478 10/20/2015 11:23 PM
Thanks everyone. I have those bolts off, and now the engine is separated from the transmission by about an inch or two, but now it is stuck again. What else needs to be removed?
Bryce S. #1130479 10/20/2015 11:23 PM
I can wiggle the engine side to side and up and down, just not forward.
