1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1130062 10/18/2015 6:39 PM
Is there a difference between a differential cover gasket and a differential carrier gasket? If different thicknesses, is the difference critical on the carrier side?
Note: Felpro and many parts suppliers list Felpro RDS5088 as a differential cover gasket, and RDS5090 as a differential carrier gasket for 47-54. However, these are not the correct gaskets.
52 3100 project
54 3100 / 3112 ice cream truck, next project
The carrier gasket is a thin paper gasket, putting the wrong gasket in can cause tolerance issues.
Bill Burmeister
Thanks. The one I used on carrier side looks about 1/16" thick. Would that cause play in the spider gears? Guess I better redo it.
52 3100 project
What it will do is set the axles up at a slight angle, could be hard on the axle bearings.
My Blog
Third members have been installed with RTV for about 25 years or so. During the transition period we retrofitted the thin paper gaskets with RTV without any problems. I'm sure the RTV was a little thinner than paper. And we have zero leaks with RTV.
I religeously use "The Right Stuff" in lieu of gaskets for everything and absolutely love it. Never a drip of anything gets through it. Expensive but excellent product.
1953 GMC 1-Ton Pickup with 350 and 700R4
I agree with Chad M regarding Permatex Right Stuff. When prepped properly, you don't even get seepage of oil or grease, let alone a drip. It is somewhat adhesive so I don't use it on things that you anticipate would need to come off, such as a valve cover. It would be perfect for the differential carrier. I have commented on this product before and surprised that few people seem to use it. It is OEM on Caterpillar oilpans and used without a gasket.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
