9 members (KEVINSKI, Sjm, tclederman, Oswald, Cosmo, Otto Skorzeny, mick53, 2 invisible),
145
Mod | | | Forums66 Topics128,260 Posts1,058,288 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Is there a difference between a differential cover gasket and a differential carrier gasket? If different thicknesses, is the difference critical on the carrier side?
Note: Felpro and many parts suppliers list Felpro RDS5088 as a differential cover gasket, and RDS5090 as a differential carrier gasket for 47-54. However, these are not the correct gaskets.
52 3100 project 54 3100 / 3112 ice cream truck, next project
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The carrier gasket is a thin paper gasket, putting the wrong gasket in can cause tolerance issues.
Bill Burmeister | | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Thanks. The one I used on carrier side looks about 1/16" thick. Would that cause play in the spider gears? Guess I better redo it.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | What it will do is set the axles up at a slight angle, could be hard on the axle bearings.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2008 Posts: 4,983 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,983 | Third members have been installed with RTV for about 25 years or so. During the transition period we retrofitted the thin paper gaskets with RTV without any problems. I'm sure the RTV was a little thinner than paper. And we have zero leaks with RTV. | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | I religeously use "The Right Stuff" in lieu of gaskets for everything and absolutely love it. Never a drip of anything gets through it. Expensive but excellent product.
1953 GMC 1-Ton Pickup with 350 and 700R4
| | | | | Joined: Apr 2007 Posts: 1,044 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,044 | I agree with Chad M regarding Permatex Right Stuff. When prepped properly, you don't even get seepage of oil or grease, let alone a drip. It is somewhat adhesive so I don't use it on things that you anticipate would need to come off, such as a valve cover. It would be perfect for the differential carrier. I have commented on this product before and surprised that few people seem to use it. It is OEM on Caterpillar oilpans and used without a gasket. Kent | | |
