7 members (Gdads51, 55shaker, 1954gmc9314, carbking, J Lucas, dt235sd, 2-Ton),
52
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,022 Posts1,055,274 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | So I've decided to go with a cable gas pedal. Would like to know what y"all have used.
Julian Carter
1970 Triumph GT6 1967 Triumph TR4A 1952 Chevy 3600 1948 MG-TC
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | LOKAR makes a nice set up but they sure are pricy. Have one on my "Burb" but it was there when I bought the truck.
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | mine is from a 74 Chev Nova | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I just installed a LOKAR floor mount pedal and cable. This one.
http://www.speedwaymotors.com/Lokar-FMG-6098-Eliminator-Floor-Mount-Throttle-Pedal-Billet-Alum,515.html
A very easy install. You also need to buy a cable separately. Also an easy install, but carefully measured. Yes, pricey.
Drew
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I use an S-10 pedal and a 75 Buick cable. You can use whatever fits. | | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | Yes Lokar is who I decided to work with
Julian Carter
| | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | I went with the RPC pedal. I think it was $40 and its the same as the lokar one. | | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | This is the exact one i got. Ok maybe around $60 then not $40. Rpc 8504 | | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | Its easy to install. All i had to do was run a cable straight up the fire wall from the pedal bracket then just loop it to the carb linkage.
[URL=http://s96.photobucket.com/user/mazdacub/media/1949%20Chev/DSC00258.jpg.html]Cable install[/url]
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Its easy to install. All i had to do was run a cable straight up the fire wall from the pedal bracket then just loop it to the carb linkage.
[URL=http://s96.photobucket.com/user/mazdacub/media/1949%20Chev/DSC00258.jpg.html]Cable install[/url] That is how mine runs on a single Rochester 2G. Very smooth operation. I used a Speedway bracket rather than LOKAR because no kick down was needed.
Drew
| | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | I am currently fabricating a setup using the stock pedal, 1/8" steel plate for a pedal "arm", and a Jegs cable assembly. I am also custom fabricating a bracket to mount to the carb base.
1953 GMC 1-Ton Pickup with 350 and 700R4
