3 members (GRNHydra, Peggy M, Rnl364), 81 guests, and 3 robots.
Topics128,064
Posts1,055,859
Members48,428
#1119854 08/19/2015 3:28 PM
So I've decided to go with a cable gas pedal. Would like to know what y"all have used.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
LOKAR makes a nice set up but they sure are pricy. Have one on my "Burb" but it was there when I bought the truck.
mine is from a 74 Chev Nova
I just installed a LOKAR floor mount pedal and cable. This one.
http://www.speedwaymotors.com/Lokar-FMG-6098-Eliminator-Floor-Mount-Throttle-Pedal-Billet-Alum,515.html
A very easy install. You also need to buy a cable separately.
Also an easy install, but carefully measured.
Yes, pricey.
Drew
I use an S-10 pedal and a 75 Buick cable. You can use whatever fits.
My 46 GMC on Photobucket
Yes Lokar is who I decided to work with
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
I went with the RPC pedal. I think it was $40 and its the same as the lokar one.
This is the exact one i got. Ok maybe around $60 then not $40.
Rpc 8504
Its easy to install. All i had to do was run a cable straight up the fire wall from the pedal bracket then just loop it to the carb linkage.
[URL=http://s96.photobucket.com/user/mazdacub/media/1949%20Chev/DSC00258.jpg.html]Cable install[/url]
That is how mine runs on a single Rochester 2G. Very smooth operation. I used a Speedway bracket rather than LOKAR because no kick down was needed.
Drew
the left side crankcase [of my 292], under the intake and exhaust manifolds has a plate mounted bell crank
a stock accelerator foot pedal to a 1/2'' box tube to bell crank, to cable with heat tape wrapped lokar cable to my edelbrock 500.
simple but not so .......
http://s67.photobucket.com/user/1951otter/media/7A-2.jpg.html?sort=6&o=117
http://s67.photobucket.com/user/1951otter/media/4495365-R1-020-8A_1.jpg.html?sort=6&o=65
http://s67.photobucket.com/user/1951otter/media/4495365-R1-008-2A_1.jpg.html?sort=6&o=62
Jim & Caroline
I am currently fabricating a setup using the stock pedal, 1/8" steel plate for a pedal "arm", and a Jegs cable assembly. I am also custom fabricating a bracket to mount to the carb base.
1953 GMC 1-Ton Pickup with 350 and 700R4
