0 members (),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | installed buckets and headlight assembly ,then (after some experimenting) the trim ring with the rubber gasket . one side slid on very nicely,but the other side is low and I was able to slide it on ,but it seems like it is not centered | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | so after reassembling a couple of times ,it seems like the repo headlight bucket is not the correct depth ,the headlight adjustable holder does not sit in as deep as the other side
Has anyone else seen this ? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | For what its worth...had trouble with one of mine going in place. Turns out the wire clip at the top was just bent to much to fit and let the rim go where it needed. I changed the clips to some old ones I had kept and it worked fine. The new ones would not let the rim go "back" far enough. Just a thought. | | |
