| | | Forums66 Topics128,162 Posts1,057,047 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Does anyone have some tips on how to do this so it looks presentable? It is chrome and probably should be sanded and primed first. I know I could just buy the decals... but I just don't like them. A stencil would handy. Steve | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I saw an episode of Power Block TV where Jimmy used a Duplicolor Paint cartridge scratch remover touch-up system to do exactly that. Its like a Pen for paint that you can control. I would think that episode is available, but I haven't been able to find it. It looked to me like the PERFECT thing for the hood emblem, hubcaps, etc, etc. | | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | You could buy the decal, remove the letters and use whats left as a stencil. Its sticky. You may have to cut it to fit the emblem. Carl
| | | | | Joined: Nov 2014 Posts: 623 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 623 | I bought the decals, and although I wondered if they could be any good or decent looking, I have to say I'm pretty happy with them! They look good, were easy to apply and were cheap. If you try them and don't like them ,just take them off and then paint them. Have you ever tried them? If not, how can you know you won't like them?
"When I rest, I rust" 1951 3100 5 window w/ '56 235
| | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Deve, sounds like a neat idea. Please let me know if you find it and you can send a PM. Steve | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | thanks Carl, I think I'll try it. Steve | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Well, you make a good point. They certainly don't cost very much. Thanks, Steve | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Here is a very good shot of a NOS piece should you try paint. I paint all of my parts like this with spray enamel, usually good quality model paint (Testors) or Rust Oleum. First, I mask as well as I possiblly can, for some difficult areas I coat them with Vaseline, things like inside portions of numbers/letters. I then spray the color and within 10-minutes I remove the masking tape (3M Blue) and the Vaseline with a Q-tip. Then I use Bamboo skewers (they come in a bundle, most grocery stores), these have a very sharp point which I then use to remove the tacky enamel along tape lines. Is it time consuming, yes, but I have used this to make nice finishes on gas pumps, Coke machines, and my truck parts. https://www.flickr.com/photos/advance-design_parts_co/16025567349/in/album-72157631868452754/ | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | I saw an episode of Power Block TV where Jimmy used a Duplicolor Paint cartridge scratch remover touch-up system to do exactly that. Its like a Pen for paint that you can control. I would think that episode is available, but I haven't been able to find it. It looked to me like the PERFECT thing for the hood emblem, hubcaps, etc, etc. Deve/53Moving on- Use Brad Allen's technique described above. I am not familiar with "Jimmy", but his touch-up paint job with those pens is probably flaking by now, or at least that has been my experience. Brad Wrench Fetcher, PhD | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Hey Brad, this looks like a easy enough technique. Did you sand or steel wool and prime first? Steve | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | If needed I will rough up the surface for prep. On Coke macines I have done a couple letters a day of the raised letters and Coca Cola script so I don't mask over drying enamel. If the surface is already painted or clean I just mask and shoot. Like i said it can be time consuming but most good applications of paint are anyway. | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Thanks for the sharp pictures Denny. Looks great. Steve | | |
