| | | Forums66 Topics128,043 Posts1,055,605 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | hello everyone. i have a 55 first series 1/2 ton that has a bracket on the pickup box that i can't identify. it is located on the front edge of the drivers side rail between the box and the cab. it looks as though it could hold a small rod or pole of some kind[3/8"or so] that would point outward horizontal to the to rail. it appears to be a factory item because of the way it is fastened to the corner. is it a part of the spare wheel assembly? does anyone know what it could be?
our garage is a non-profit organization
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | It is part of the side mount spare. | | | | | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | hello and thanks metalman. i have the spare mount assembly, but i am not sure how this bracket is involved. in an earlier post you called it a tie in bracket. does it connect somehow to the mount? if it does, perhaps i have a peice missing.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | The wieght of a tire and wheel bouncing around can put a big strain on the bed. This was used to give the bed side extra stiffness at the top by joining it with the front panel at the very top. This part is often missing when buying a used side mount spare unit. I have made many. | | | | | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | thanks for the explanation metalman. i'll bet that it is overlooked quite often.
