1 members (Rusty Heaps), 114 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#112870 04/21/2003 12:34 AM
hello everyone. i have a 55 first series 1/2 ton that has a bracket on the pickup box that i can't identify. it is located on the front edge of the drivers side rail between the box and the cab. it looks as though it could hold a small rod or pole of some kind[3/8"or so] that would point outward horizontal to the to rail. it appears to be a factory item because of the way it is fastened to the corner. is it a part of the spare wheel assembly? does anyone know what it could be?
our garage is a non-profit organization
#112871 04/21/2003 10:05 PM
Anonymous
Unregistered
Anonymous
Unregistered
It is part of the side mount spare.
#112872 04/21/2003 11:09 PM
hello and thanks metalman. i have the spare mount assembly, but i am not sure how this bracket is involved. in an earlier post you called it a tie in bracket. does it connect somehow to the mount? if it does, perhaps i have a peice missing.
#112873 04/22/2003 2:56 AM
Anonymous
Unregistered
Anonymous
Unregistered
The wieght of a tire and wheel bouncing around can put a big strain on the bed. This was used to give the bed side extra stiffness at the top by joining it with the front panel at the very top. This part is often missing when buying a used side mount spare unit. I have made many.
#112874 04/22/2003 9:23 PM
thanks for the explanation metalman. i'll bet that it is overlooked quite often.
