Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (klhansen), 103 guests, and 2 robots.
Topics128,281
Posts1,058,466
Members48,490
#1127089 09/30/2015 2:19 PM
I remember seeing a post in the past where a gentleman was working on a prototype for a kit for front disk brakes mounted on the original solid 1-ton axle. Has anyone tried them?
1949-52 Chevy 3800 1-Ton Flatbed
More pix on Photobucket
Mine is in the works and I will report from the mechanic when complete. It was the Hollister and they have been excellent on the communication and concern that I had the correct parts. I also have a one ton and PTO, so the linkage part will be the question. Get the remote Master cyl fill also with the booster and dual master cylinder.
Awesome, I too have the 1-ton with a PTO so let me know how it goes. I am to the point I need to start thinking about a Master cylinder and pluming and want to get the correct part the first time around. Right now I have the OEM front drums and rear drum brakes on a 14 Bolt. I'm ok with the rear being drums but wanted to explore the front disk conversion.
1 Offline
I'm to the point where I need to replace the front drums because of wear. I've seen several disc conversions but never followed up. I need to now.
1951 3800 1-ton
In the DITY Gallery
Moderated by  Dusty53
