1 members (homer52),
118
Mod | | | Forums66 Topics128,281 Posts1,058,469 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 208 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 208 | I remember seeing a post in the past where a gentleman was working on a prototype for a kit for front disk brakes mounted on the original solid 1-ton axle. Has anyone tried them? | | | | | Joined: Aug 2011 Posts: 229 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 229 | Mine is in the works and I will report from the mechanic when complete. It was the Hollister and they have been excellent on the communication and concern that I had the correct parts. I also have a one ton and PTO, so the linkage part will be the question. Get the remote Master cyl fill also with the booster and dual master cylinder. | | | | | Joined: Jan 2015 Posts: 208 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 208 | Awesome, I too have the 1-ton with a PTO so let me know how it goes. I am to the point I need to start thinking about a Master cylinder and pluming and want to get the correct part the first time around. Right now I have the OEM front drums and rear drum brakes on a 14 Bolt. I'm ok with the rear being drums but wanted to explore the front disk conversion. | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | I'm to the point where I need to replace the front drums because of wear. I've seen several disc conversions but never followed up. I need to now. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | |
