7 members (52Carl, joe apple, Otto Skorzeny, 55shaker, Gray_Ghost, Hush, JW51), 147 guests, and 2 robots.
Topics128,108
Posts1,056,238
Members48,437
#1126709 09/28/2015 3:57 PM
I found a 235 in great shape. Now I need to get it home. What is the best way to tie this down in my pickup? Looking for some ideas here as I dont want to be making a turn and hearing it slam around the bed of my truck. Thanks!
A old tire and some motorcycle straps.
Give me ambiguity
or give me something else
U
U Offline
Or make one of these.
The tire method works great; I've done that several times with various engines & odd-shaped heavy steel items. I've also made several of the wood carts, and that's what I use now for stovebolts. Use some good straps.
Brad
Wrench Fetcher, PhD
Tire method is just plain easy and it works well. You might do the seller a favor by taking a tire off his hands.
hey uncle brad, those are great plans. I have two engines (stove bolts) in my shop these plans will let me roll them out of the way. Thanks so much
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
Brad
Is the lumber "off the shelf" measurements or true measurements? My experience is the 1X4 at the lumber store is 3/4" thick.
Great plan Brad. Looks like it would do the job. Now all I need to do is find a 235. Steve
I built one of the wood carts to store my spare 261 in the shop. It works great and is handy when moving the engine around.
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
i used modified plans and built one of these for garage work and support
1929 Engine Stand on HF Dollies Design
1929 Engine Stand on HF Dollies Design w/ Drivetrain
Links to My Engine Stand Build Build have drawings posted somewhere if interested
1929 Chevrolet AC International - 4 Door
1930 Chevrolet AD Universal - Canopy Express Truck
Love the Antique Chevrolet's from 1928-1932
The Beauty, Simplicity, History, and the Stories they Tell
[/font]
- - In the Stovebolt Gallery
-- In the Gallery Forum
I bought a 250 today. Used a tire in the back of the pickup as a nest for the oil pan. Straps held it steady for 2 hours. Bought a HF 30" mover's dolly for $13.69 and it has a 1000# capacity. Used the tire and a 10" piece of 4X4 wood. It is very stable and I doubt it will tip, but I don't have any small children running around either. See for yourself.
I plan to make a real dolly like the ones in the plans but this will work for a few weeks until I get around to making a run stand.
I did wind up building one of the wood stands. Brought it along to pick up my engine and it worked great. It is now in my garage and I am able to roll the motor off to the side when not working on it. Thanks for the advice! would recommend it to all.
I just finished making an engine dolly using the plans in the earlier post. However, I simply rested the cradle on top of a HF mover's dolly. I made the cradle longer so I didn't have to change the size of the dolly or the location of the wheels. Here are the photos of the finished engine dolly.
yes, these stands work great, I built a couple for one of my gmc v6s with some tweaking to the original plans to make it fit, but it also works well for v8s.
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
