2 members (cmayna, Gray_Ghost),
168
0
Mod | | | Forums66 Topics128,114 Posts1,056,613 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 26 | I'm looking for the windshield inner trim for my friend's '51. I contacted Winter Lane @ nospartsfromthepast.com but he does not have them. I've tried Jim Carter, LMC Trucks, Bow Tie Bits, Filling Station, Chevs of the 40's, Classic Parts of America, Brother's Trucks, NPD, and Eckler's. Most offer the outer SS trim, but not the inner trim. Any ideas of where I can get these?
David A Johnson Hobe Sound, FL | | | | | Joined: May 2013 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2013 Posts: 51 | I don't belive they make those. Used is your best option
Jon
1947.5 Chevy 4100 red primer 1951 Chevy 4400 grey primer
| | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** Give RPM Motorsports out of Minnesota a call at 1-507-377-1138 they will probably be able to fix you up. They show up on Ebay often as well. Take a look at ebay # 151831066867 states for a 52 but 51 is the same.
| | | | | Joined: Apr 2013 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 26 | To marzach: Thank you for the info. I called RPM who said they were temporarily out of stock but expected more on their next truck in 3-4 weeks. I'll try back then. I also looked on ebay using the number you gave me and there was a pair of inner trim pieces up for auction. I placed a bid, but the bidding doesn't end till this coming Sun nite. I'll check back right before it closes to see if I'm still top bidder. Thanks again.
OldRustyWrench52 | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ..and even if your still the top bidder you may want to bump it a little at the last minute as a lot of folks wait until the very last to put in their bid and hope to win. A couple dollars more may insure you get it. Depending on what your willing to pay. | | |
