4 members (Hotrod Lincoln, KCMongo, Peggy M, eclector), 166 guests, and 2 robots.
Topics128,034
Posts1,055,533
Members48,425
#1126071 09/24/2015 11:12 PM
I need to put a new grille in my burb. The chrome plating on the original is all flaking off. My question is can the grille be installed in one piece? I have the front clip off the truck so it would be easy to work from behind instead of trying to work through the headlight holes. If I recall correctly I had to install the original piece by piece. So experts, can it be done in one fell swoop?
Weeds
1949 Chevrolet truck
It looks like the grill assembly is removed and installed as one-piece.
The radiator grill upper baffle and lower baffle are not parts of the grill assembly.
Do the disassembly and assembly instructions in the Shop Manual answer your question?
Its a good idea to loosen the inner fender-to-fender bolts, and the top bolts of the radiator support, and any others as necessary. Be prepared for fitment issues with aftermarket grills, especially at the top corners. Having everything loose will help you avoid scratching the paint while you are wrestling with it.
I did my repop in one piece. As Carl suggested loosen everything and get everything made before you start to tighten. I used a lot of drift pins and screwdrivers in the process, I never thought it would fit but it did.
Don't know about the repro grills, but the original grill goes
in as one assembly. Remember, it's all riveted together. But
as Carl and Brad posted, have everything loose and a
handful of drifts. If you've got the clip off the frame then
it should be a a walk in the park, well.....almost.
Pete worked with me when we put my '50 front clip back together
and it really helped to have two people doing it. There would
have been some real foul language coming out of that garage
had I tried doing it by my self.
How bout those two strapping boys of yours, din't they assist
you the first time? I'm sure they'd give dad a helping hand?
dg
Denny G
Sandwich, IL
And if it is repop clean the chrome a few times a year, it will age fast, mine is garaged all the time and I am surprised how fast things want to rust
