4 members (38Kiwi, UtahYork, dt235sd, Hotrod Lincoln), 123 guests, and 2 robots.
Topics128,196
Posts1,057,390
Members48,471
#112575 05/17/2004 7:33 AM
Junior Member
Junior Member
I just read in my "bible", How to Restore Your Chevrolet Pickup, that the top of the dash on the Task Force pickups had a non glare finish applied to it. I am tring to do a very careful restoration on my 58 and can not find what this product is and where I can get it. Also how far down on the black top portion of the dash this coating was applied? Ok it's time to help the "rookie" again. Thanks, I will be loading up some pictures in the future to show the progress. This website is top notch!!!!!
#112576 05/17/2004 3:49 PM
I used dark grey gravel guard to reproduce the rough finish on the dash of my '56. I think I got it from a vendor some time ago. Turned out better than I hoped.
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
#112577 05/18/2004 8:47 AM
Junior Member
Junior Member
56picup, sounds like a possibility, I will see if there are any other ideas out there but that just might work. Hope the 56 is looking good. 58 stepside
#112578 05/21/2004 2:01 PM
I may be way off base but what about adding some flatning agent to the dash paint?
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#112579 05/21/2004 4:01 PM
Flat or semi-gloss paint works great but doesn't give the dash the original rough finish look. Most of the '55.2 and '56 trucks I've seen have had smooth paint on the dashes, but I remember that the one I drove in the late 50's didn't have a smooth dash so tried to create that look.
1956 Chevy 3100
#112580 05/23/2004 10:43 PM
Junior Member
Junior Member
I thought that the rough finish was as result of a bad paint being sprayed on the dash some point in the trucks life I guess thats the way it came it does look too well applied to be a spray can, I must admit I am stripping it off and going with shiney hi glare pearl white, I'll have to wear shades!!!!!!!!!!!!!!
John Taylor,Brampton ontario
#112581 05/24/2004 2:49 AM
I was in orchard supply hardware the other day and spotted a new paint from "Rustoleum" called textured. Came in flat black and a few other colors. This is not the "hammered" or "splatter" paint thats been around for some time. It appears to be of the same texture that is currently on my original '59 dash.
#112582 05/25/2004 8:07 AM
Junior Member
Junior Member
Thanks for the additional suggestions. I have to admit to my lack of mental fortitude on this one. My dash had this "rough bubbled" paint on it but I too thought it was someones poor paint job and sanded it smooth. I guess lesson learned here "research twice, put the sandpaper down and research again!" oh well> I keep hoping someone will say there is a product specially made for this restoration application. I will look into the Rustolium idea, will let you know what I think.
