| | | Forums66 Topics128,196 Posts1,057,391 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 27 Junior Member | | Junior Member Joined: May 2004 Posts: 27 | I just read in my "bible", How to Restore Your Chevrolet Pickup, that the top of the dash on the Task Force pickups had a non glare finish applied to it. I am tring to do a very careful restoration on my 58 and can not find what this product is and where I can get it. Also how far down on the black top portion of the dash this coating was applied? Ok it's time to help the "rookie" again. Thanks, I will be loading up some pictures in the future to show the progress. This website is top notch!!!!! | | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | I used dark grey gravel guard to reproduce the rough finish on the dash of my '56. I think I got it from a vendor some time ago. Turned out better than I hoped. | | | | | Joined: May 2004 Posts: 27 Junior Member | | Junior Member Joined: May 2004 Posts: 27 | 56picup, sounds like a possibility, I will see if there are any other ideas out there but that just might work. Hope the 56 is looking good. 58 stepside | | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | I may be way off base but what about adding some flatning agent to the dash paint?
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | Flat or semi-gloss paint works great but doesn't give the dash the original rough finish look. Most of the '55.2 and '56 trucks I've seen have had smooth paint on the dashes, but I remember that the one I drove in the late 50's didn't have a smooth dash so tried to create that look. | | | | | Joined: Apr 2004 Posts: 11 Junior Member | | Junior Member Joined: Apr 2004 Posts: 11 | I thought that the rough finish was as result of a bad paint being sprayed on the dash some point in the trucks life I guess thats the way it came it does look too well applied to be a spray can, I must admit I am stripping it off and going with shiney hi glare pearl white, I'll have to wear shades!!!!!!!!!!!!!!
John Taylor,Brampton ontario
| | | | | Joined: Jan 2004 Posts: 112 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 112 | I was in orchard supply hardware the other day and spotted a new paint from "Rustoleum" called textured. Came in flat black and a few other colors. This is not the "hammered" or "splatter" paint thats been around for some time. It appears to be of the same texture that is currently on my original '59 dash.
| | | | | Joined: May 2004 Posts: 27 Junior Member | | Junior Member Joined: May 2004 Posts: 27 | Thanks for the additional suggestions. I have to admit to my lack of mental fortitude on this one. My dash had this "rough bubbled" paint on it but I too thought it was someones poor paint job and sanded it smooth. I guess lesson learned here "research twice, put the sandpaper down and research again!" oh well> I keep hoping someone will say there is a product specially made for this restoration application. I will look into the Rustolium idea, will let you know what I think. | | |
