5 members (IHPWR, Peggy M, 55shaker, 1955 1 Series, 1 invisible), 78 guests, and 1 robot.
Topics128,211
Posts1,057,468
Members48,471
Page 1 of 2 1 2
Question: I'm burning a lot of oil. Am I going to foul plugs or run into other issues soon?
My high hopes have been deflated. I pulled a 1971 250ci with unknown mileage from a 1966 C10 parts truck I bought. Compression checked out OK and it ran pretty good with a freshly rebuilt carb so I decided to use it. It was free to me since it was from my parts truck and I really didn't see much potential for selling it. I cleaned it up inside and out and made it pretty. HEI and Rochester B. I finally got my 1965 C10 road worthy 2 weeks ago and I'm on my 2nd tank of gas.
I replaced every gasket and seal except the head gasket and freeze plugs. I have no leaks.
When I drive in the early morning, I can see a light trail of smoke in the headlights of the car behind me. During the day I cannot see it smoke in my mirrors, but if I goose it, it will smoke.
My PCV is hooked up correctly. Starts easily and runs very well IMO. I think I use about 2.5 quarts of oil per tank full. Yikes. Tailpipe has black soot.
So what next? I plan to run the engine until I get some upgrades to brakes and steering done. Then bodywork. Then pull it apart and paint the truck.
I know a more modern engine might be cheaper than a total rebuild of this engine. But then I'll need to change to fuel tank under the bed, fuel injection and a bunch of other fairly costly "other" issues. I really like the unique and original looking L6.
Id expect to see some degree of smoke like you're seeing on a 'free' engine like that... I ran a qt of MMO through a Studebaker 289 both in the oil and the gas and was amazed how much cleaner it ran. It had sat for years like yours and was close to 1K miles on odometer.
It went from mozzy fogger to misting tailgaters like your describing. It might clean yours up enough to get you in the 1qt/tank range... for free I'd live with that and be glad I had a built in tailgater 'back off' tool to to use on unwelcome commuters riding my bumper.
Give me ambiguity
or give me something else
I'll run some MMO through the oil. I've never added it to fuel. I guess that's something I can try too. My theory is that it need new rings. I plan to do a leak down test too.
Just got off the phone with O'Reilly and they want around $1650 for a rebuilt 250ci long block plus a core exchange. Comes with a 3 year unlimited mileage warranty.
I'm gonna check the local machine shop for a price. That way I could order the cam I want.
I can't be certain but I think it was the MMO in the gas that made the real difference.
That long block price is about half of what my machine shop bill was for my 270 FYI. (and I had to reassemble everything)
Give me ambiguity
My local machine shop wants same money but has less warranty. I really need to do a leak down test. I have my original 1965 230ci sitting under a tarp. Maybe I could go play with that. Had low compression in 3 cylinders but it ran. Maybe just sticky valves. Hmmmmmm. ohwell
Try adding a couple of quarts of kerosene or Diesel fuel to the oil, enough to bring the oil level about 2" above the full mark. Then run the engine at a fast idle (1200-1500 RPM) for about 15 minutes, with no load on the engine. Drain the crankcase and change the filter while the engine is hot, and refill with straight HD-30 oil. It can't hurt, and you just might de-carbon the ring grooves enough to get a better seal against the cylinder walls.
Jerry,
Your advice has always helped me. But I must say that this advice is "over my head". ohwell
I poured kerosene all over this engine and sprayed it inside and out with kerosene when I cleaned it up. Sprayed kerosene down inside the cylinders and all over the head (still bolted on). Cleaned all the oil and carbon off the rocker area with kerosene when I removed the valve springs and rockers to put new valve stem seals on. Clean enough to eat off the engine. The only thing I didn't clean was where the head bolts to the block. Never removed the head.
So adding kerosene to the oil will wash out carbon deposits, right? What's all this talk about carbon on the ring grooves? What in blazes is that?
I guess one could think of the carbon in the ring grooves as the dirt hiding under fingernails?
Give me ambiguity
Originally Posted by CASO
I guess one could think of the ring grooves as the dirt hiding under fingernails?
Is this in the cylinder walls or on the rings themselves? I can't picture it.
In the piston groove where the rings live. Keeps them from rotating and flexing properly. Cheap and will do no harm, if done as HRL suggests. Will also dissolve any dirt in the oil system so a plus for that.
Steve H
Ahhhhh! Light bulb just came on in my head. Thanks. New terminology for me. Haha! Isn't it fun having a total newb as a student? I know just enough about engines to get myself in trouble and waste a lot of money. Thanks.
5 Online: Content
Lugnutz, you think we were all born knowing this stuff? Down the road you'll be sharing what you learned to other people also.
Brian
1955.2 3100 Truck
And hopefully you will be able to share it in an artful, kind, polite, heart-warming and diplomatic manner as HRL does! smile
Truthfully I wish there was a place on this site where you could go to and see all of the priceless tips which he shares. Especially the quick hitting ones that make you say, "Why didn't I think of that?"
Carl
Yep. He taught me how to put my harmonic balancer back on. The kind without a bolt where you heat the center of the balancer, grease the snout and tap it on.
Overfilling the crankcase turns the crankshaft into a very efficient washing machine agitator. Just don't try to drive the vehicle, as the solvent destroys a lot of the lubricating and load-bearing properties of the oil. It's OK to run the engine as long as no driving load goes on the bearings.
Carl, being able to be a blunt, insensitive, and just a bit irritating old geezer is one of the few perks I can think of after spending 50-something years wrenching on these old rigs! The aches, pains, and scars of half a century of doing dumb stuff, not so much!
LOL!
Q
Q Offline
Valve seals leaking? Very common on oldergm v8 and 6's. Another method of cleaning out a block is to drain the oil and refill with atf and a couple qts of engine oil. Warm the engine up,run it for a couple blocks, and drain the oil. Do the filter too. Atf has a high detergent agent in it and works well for cleaning out the engine. The nice thing is that it is safe to drivefor a short time.used this method lots in in the past and is real effective in cleaning up hydraulic lifters.however if doing this and the solvent treatment doesn't work then the rings are done and that's it.! I'm not discrediting the solvent treatment....never tried it as the atf worked so wellong for me. Also have seen but never used is a additive for engine oil that works the same as atf,I don't recall what it is called.
Valve seals are all new. Only seal I didn't replaced was head gasket and freeze plugs. I will wash it out in the next 2 weeks and update everyone.
Just finished a dry compression test. Took pics of my plugs too. Engine and plugs were stone cold when I pulled the plugs. Plug #3 looked slightly darker than the other 5 plugs.
All plugs were out and my wonderful wife cranked the engine for 4 complete bumps of the gauge needle. Here are the compression numbers. Factory service manual says a 230ci should have 130# and I imagine the 250 would be the same.
Cylinder #1 - 125
Cylinder #2 - 125
Cylinder #3 - 110
Cylinder #4 - 125-130
Cylinder #5 - 125
Cylinder #6 - 120
HERE is the link to my photobucket pics showing the plugs.
Plugs look good, not to sooty or oily. Have you had it on a long highway trip? A 50 mile trip each way at a steady rpm and decent speed may just loosen up the rings and get the oil usage down. Get the engine good and hot. The muffler could have excess oil in it thats just burning out from the old valve seals so it could take awhile to clean out.
Joe
Joe
Thanks Joe. Entire exhaust is new. Manifolds were clean when I installed them with a new gasket. Longest trip has been 20 miles one way. I am puzzled to say the least but a novice so I need to run everything by folks who know. That way I won't waste money with the wrong diagnosis.
Video of exhaust 30 seconds after cold start. Choke still on and RPMs range 1500 - 4000 in video. White and black smoke. Looks pretty grim.
Jay
You say unknown miles on this engine and it burns to much oil... but the plugs look ok and the compression is workable...
I think you need to drive that sucker a good couple of gas tanks, (keep the MMO in the gas tank too) and give it a chance to settle down.
If that's all the worse it smokes on warm up what's the problem? You live in a snooty community or something? ohwell
Show us a video looking out the back window as you run it up through the gears on the road, then maybe that will show something scary or more indicative of the problem. pix
Give me ambiguity
Haha! No snooty neighborhood here. People on my block know me as the guy always messing with something on the truck or one of my cars.
Three more videos.
First is after a 5 minute drive.
Second is holding RPMs steady at normal driving RPMs.
Just a few seconds under the hood.
Jay
If it's running rich (the black smoke) it could be washing down the cyl walls I guess. Its an old engine that's why someone quit using it... Just buy oil by the gallon and remind yourself 'this is what it was really like in the old days'
DO the other stuff you mention in your first post and see what this does (after you adjust the carb) over the winter.
Is it a DD? how many miles a week does it see?
Give me ambiguity
Q
Q Offline
Doing a cold compression test is not accurate,when components are cold they are in a contracted state,thus giving lower compression readings. Warm the engine up to operating temperature. Pistons etc will expand and give you more accurate readings.compare your hot and cold to see the difference it makes.the hot readings are what you have driving,which is the true picture. Would be interesting to see the difference on #3. If you do have new valve seals then I suspect rings are the issue. Check your pcv system and make sure it's not plugged or the valve isn't gummed up.
I say valve guides are worn, need to have the guides knurled or replaced. Just pull the head and have a competent machine shop do a valve job on the head.
Tommy
59 apache 1/2t
261 short stepside
Q
Q Offline
Guides are possible,although with new seals it shouldn't be to much of an issue.biggest indication of seals or bad guides being bad is a cloud of smoke on start up that clears up quickly.when engine is shut off oil seeps past seals and ends up pooling on backside of the valves. Now if guides are completely thrashed then valve stems could flop around oil could get by the sears. But for them to be worn out enough to leave a constant trail of smoke out the tail pipe? I don't know about that,I've never run across that being the issue. But you never know right?!!
I ran one of these in a 68 Nova for ever(250,000 miles) It never smoked, but did have a ton of blow by. Would vent out the cap on the valve cover. Biggest issue was the PCV valve. It would get sticky and push oil into the intake. Cheap part and easy to change. Caused all sorts of running issues when it would go bad. It could be just that easy. Compression was good, but a lot of wear and loose pistons were my real problem. By 1978 it was done. Ball joints were the reason I got rid of it. Back then the car was worth about 800.00 and the parts alone were more than that. Try the PCV valve and see what happens.
Steve H
In recent posts (on other subjects) I've confessed some of my embarrassing mistakes. It is entirely possible that I installed my NEW valve seals improperly. Heavier weight oil would only be a Band-Aid if the valve seals are the problem. I did all this work 2 years ago and memory is fuzzy as to the method used.
Please - someone tell me how to inspect the seals to see if I did it properly. Will it require compressing the spring and removing the cap and locks? I imagine so.
EDIT** Never mind. I found pictures that document my installation method. It was done properly. Pretty sure valve seals are not the problem.
Jay
I really appreciate the willingness everyone has to try and help a novice like me.
Here's an update. FYI, this is the third time I've eaten Humble Pie this month. Not very fun.
My 1971 250ci engine is pretty on the outside and junk on the inside. I added ATF to the oil and drove it maybe 40 miles. I saw the oil pressure light flicker once or twice at really low RPMs and that made me wonder if some gunk had blocked the oil pressure sensor.
I added a quart of kerosene to the oil and idled the engine in the yard at 1500 RPMs for 14 minutes. Drained everything while hot and changed the filter and replaced the oil pressure sensor with a new one. Oil came out dark brown but no chunks. (That was no surprise because I had removed all the gunk from the oil pan, timing cover, rocker cover and then changed all the seals 2 years ago.)
Added straight 40 weight oil to the engine in hopes that the thicker oil would reduce how much oil it was burning. Took the wife for a drive to the lake that evening and noticed the oil pressure light would flicker when at idle at the light - 800 RPMs. Light would go out immediately once I started driving. No funny noises from the engine. Checked oil level and it's all fine.
Tonight I got out my new Stewart Warner electric pressure gauge. You better read this sitting down. Operating temperature pressure is 10 at idle of 800 RPMs and never goes over 20 when driving. Stays at 20 with RPMs 2000 - 2500 and will drop to 15 if RPMs drop to 1500.
I have never rebuilt an engine. Working on this truck has been a real education and very humbling.
I really like the idea of keeping an inline 6 cylinder because you don't see that many these days. Other reasons are purely financial. The pros for installing another 250ci are many.
Keep the same (new) wiring under the hood.
Keep the brand new exhaust.
Keep the same radiator and (new) hoses
Keep the same new HEI dizzy & wires
I've already checked some prices. Crate 250ci with 3 year unlimited mileage is $1500-$1600 and I give them mine as a core.
Local shop wants similar money but only 12 months warranty.
I have an engine stand and a garage to work in this winter.
Let's hear what you think.
Jay, hey, you've did everything else you can build that engine. I know you can do it. Any problems there is a great bunch of guys here to help you through it.
Should you decide not to do it, or have someone else do it maybe give this folks a call and chat with them. They are in Johnston, S.C.
http://www.cmengines.com/Home/tabid/36/Default.aspx
My nephew has sent probably a half dozen to them and each one has been "jam up" and actually saved some money. I may end up letting them do my 4.8
Q
Q Offline
Well...you did a pretty good job of diving into the old t5 and figured that out. Rebuilding an engine is not that hard. Really the biggest part of it is the machine work. My approach is as follows. Strip it down,head gets rebuilt,block cylinders get measured so I know if it can stay standard or go with a rebore. Crank gets measured and either gets a polish and new bags or get ground to what ever size it needs to. New cam bags if needed and cam checked out. You can go with a regrind or spec.a mild cam,or what ever you want. Get that all done. Bring it home and get a good shop manual and put it all back together. Warranty...you.unlimited milage. Experience. ..priceless.you may or may not save any money doing it your self. Check engine rebuild shop for prices on their machine services,and compare,also compare prices on parts. If I were to go with a rebuild, I would go with the best warranty I could get. By comparison. ..I've got a 5.9 Cummins out of a 06 dodge that dropped an exhaust seat and damaged head and #1 piston and broke the crank. 6600.00 to rebuild,and only a low cost rebuild.that's only boring out #1 cylinder and replacing 1 piston. A complete long block is 7400.00. If I were to rebore all 6 holes in the old block it would be more than the rebuilt long block. There is a big back story to the engine that failed,I won't go into that except to say it was a badly rebuilt engine.PO had engine rebuilt before he sold it. All that to say that which ever way you go...do it right the first time.
I love my 250. It's a nice size for the '65 C10 with a 4-speed & 3.73 rear end. I did a rebuild in my home garage almost 20 years ago...it was very tired and using lots of oil. I don't remember the numbers, but it wasn't that much for machining and parts.
Wish I had known about using 307 pistons to bump the compression.
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
I would rebuild what you have. Parts are not that expensive, it's the machine work, so shop around. Do as Starfire4 mentions, and add 307 Chevrolet V8 true flat top pistons. They are a true bolt in and will raise the compression 1 point, to about 9.0 to 1. You will still be able to run regular gas but the added compression will help in the power department. Do as much of the nasty work as you can and save some money. Shop manuals will tell you how to assemble or take apart.
Joe
Alvin,
I've talked to them already and yes they have a good reputation. Unless a good engine falls into my lap I'll probably take my 230ci to them and have them do the long block. Sounds like 307 pistons and roller bearing rockers would be the only upgrades I'd want. I plan to run the stock intake and a progressive 2 barrel Weber carb. Headers are not out of the question but I'm trying to keep the cost down and I can always add those later. Sounds like I need to sell some T5s to find this. Haha!
I hope the "230" was a typo- - - -the 307 pistons won't work in that one, only the 250. The big block V8 rocker arms work on a 250, but you lose a slight amount of valve lift in the process from 1.75% to 1.7%. Have the machine shop install pushrod guide plates and screw-in rocker studs while they're reworking the head. If you install a cam with slightly better timing and lift, the .05% drop in rocker ratio isn't noticeable.
Wow! The 230 won't work? I thought it would. What if I use the 250 head?
The difference in the 230 and the 250 is the stroke. You would need to use a different crankshaft and turn it into a 250. The 230 has a 3.25" stroke; the 250 has a 3.531" stroke. The 307 piston would stop about 1/4" short of the top of the block, and the compression would be about 6:1. Performance would be a bit below par!
Ok, so it can be done. Just need to get the right parts. I have no problem spending money to get the right parts. Thanks. That simplifies life a lot. Drive the 250 until the 230 is done. Then swap.
Here's a standard diameter 250 crankshaft:
http://www.ebay.com/itm/6516-Cranks...12743927?hash=item5d46615af7&vxp=mtr
These are available pretty often, usually at reasonable prices. If not this one, there will be others. Just search "Chevy 250 L-6 crankshaft".
Page 1 of 2 1 2
