3 members (51sub, Jon G, 1 invisible),
110
Mod | | | Forums66 Topics128,288 Posts1,058,571 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | All new wiring, tight grounds, checked and double checked connections but it stays on E. And yes there is plenty of gas in the tank. My guess is the sending unit might be the culprit. Steve | | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | Did the gauge work before?
| | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Could be the float has a hole or has fallen off the sending unit. You'll have to pull it and have a look.
Ed
| | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | So if you disconnect the sender lead at the gauge, the reading should go to full. If you ground the sender connector at the gauge, it should read empty. The next step would be to disconnect the sender wire at the tank and take a reading in ohms from the connector to the ground. With a full tank it should be up near 30 ohms. If this is the case your sender wire is shorted to ground. | | | | | Joined: Sep 2015 Posts: 3 New Guy | | New Guy Joined: Sep 2015 Posts: 3 | I'm just getting started on a 52 3/4 ton restoration. It all seems original. I started by bulling the fuel tank/lines due to rust. I've secured replacement tank and lines but am having trouble locating a 6 volt fuel level sending unit. Can anyone help me? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Welcome to Stovebolt cherrypie. In order to get the most responses for a question. you need to start your own post. Steve | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Thanks for your advice. After some investigation, I discovered that on the tank sending unit the 1/4 " brass strip connected to the lead and the float has a slight bend and a crack near the top. Could this be the problem? The gauge did not work when I bought it and I followed all the instructions for the new harness bought from Classic parts. Steve | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Tim, what does voltage sensitive mean? It looks like the original. Would you suspect the problem is the crack I mentioned? I am not getting any feed back. Steve | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The sender works on either 6 volt or 12 volt, it just gives an ohm reading.
Did you remove the sender? | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Hi Gus. I have a 6v. The sender is in the truck right now. But it has been out before when I cleaned the tank. As I said, the thin 1/4" strip from the lead to the float is slightly cracked. Do you think that is the problem? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Only way to know is to test it
Did you try truckernix suggestion above? Did you get an ohm reading? | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | truckernix, a couple things I should say. the ground is attached to the cap where the sending lead is on the top of tank. The other is I do not have a ohm tester. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Hi Gus. I have a 6v. The sender is in the truck right now. But it has been out before when I cleaned the tank. As I said, the thin 1/4" strip from the lead to the float is slightly cracked. Do you think that is the problem? Can you post a photo of "the thin 1/4" strip from the lead to the float"? | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Digging up an old thread with a question... On the sending unit... The wire on the center terminal goes back to the guage. Is there another ground wire that connects to the sending unit and if so does it connect to the center terminal or an outside screw?
1953 GMC 1-Ton Pickup with 350 and 700R4
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The sender/flange is grounded by the mounting screws. Since there is a gasket there and the straps can have pads and the filler has a rubber hose and paint and undercoating....(all insulators), it's a good idea to reinforce the ground with a wire from a sender flange screw to the cab or chassis. Grounding of the sender and/or gauge is the no.1 cause of "gauge not working". Of course the ground path back to the battery has to be good also. Do not ground the center terminal.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 |
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Nicely done! With braided wire no less. Dads50 does some of the cleanest work seen here on Stovebolt.
