Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (51sub, Jon G, 2 invisible), 121 guests, and 2 robots.
Topics128,288
Posts1,058,571
Members48,492
All new wiring, tight grounds, checked and double checked connections but it stays on E. And yes there is plenty of gas in the tank. My guess is the sending unit might be the culprit. Steve
Did the gauge work before?
No, it did'nt.
Could be the float has a hole or has fallen off the sending unit. You'll have to pull it and have a look.
Ed
So if you disconnect the sender lead at the gauge, the reading should go to full. If you ground the sender connector at the gauge, it should read empty. The next step would be to disconnect the sender wire at the tank and take a reading in ohms from the connector to the ground. With a full tank it should be up near 30 ohms. If this is the case your sender wire is shorted to ground.
1951 1 Ton Completed
I'm just getting started on a 52 3/4 ton restoration. It all seems original. I started by bulling the fuel tank/lines due to rust. I've secured replacement tank and lines but am having trouble locating a 6 volt fuel level sending unit. Can anyone help me?
http://www.classicparts.com/1954-59...t-Style/productinfo/23-525/#.VftkHCBViko
The gauge must be 6v but the sending unit is not "voltage sensitive".
Welcome to Stovebolt cherrypie. In order to get the most responses for a question. you need to start your own post. Steve
Thanks for your advice. After some investigation, I discovered that on the tank sending unit the 1/4 " brass strip connected to the lead and the float has a slight bend and a crack near the top. Could this be the problem? The gauge did not work when I bought it and I followed all the instructions for the new harness bought from Classic parts. Steve
Tim, what does voltage sensitive mean? It looks like the original. Would you suspect the problem is the crack I mentioned? I am not getting any feed back. Steve
The sender works on either 6 volt or 12 volt, it just gives an ohm reading.
Did you remove the sender?
Hi Gus. I have a 6v. The sender is in the truck right now. But it has been out before when I cleaned the tank. As I said, the thin 1/4" strip from the lead to the float is slightly cracked. Do you think that is the problem?
Only way to know is to test it
Did you try truckernix suggestion above?
Did you get an ohm reading?
truckernix, a couple things I should say. the ground is attached to the cap where the sending lead is on the top of tank. The other is I do not have a ohm tester.
Can you post a photo of "the thin 1/4" strip from the lead to the float"?
Here is an Ohm meter that is cheap and works: http://www.harborfreight.com/7-function-multimeter-98025.html
6.00 dollars. Takes the guess work out.
Steve H
Digging up an old thread with a question... On the sending unit... The wire on the center terminal goes back to the guage. Is there another ground wire that connects to the sending unit and if so does it connect to the center terminal or an outside screw?
1953 GMC 1-Ton Pickup with 350 and 700R4
Sir Searchalot
Sir Searchalot
The sender/flange is grounded by the mounting screws. Since there is a gasket there and the straps can have pads and the filler has a rubber hose and paint and undercoating....(all insulators), it's a good idea to reinforce the ground with a wire from a sender flange screw to the cab or chassis. Grounding of the sender and/or gauge is the no.1 cause of "gauge not working". Of course the ground path back to the battery has to be good also. Do not ground the center terminal.
Ok thanks
Sir Searchalot
Sir Searchalot
Nicely done! With braided wire no less. Dads50 does some of the cleanest work seen here on Stovebolt.
