| | | Forums66 Topics128,154 Posts1,056,851 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2015 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2015 Posts: 26 | Is there nany way to identify if a stock 6cyl is a 216.5 or 235?mine has stamped on it on the top rim of the block 383716 GM6. I can not find any other numbers.
RB55 | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Here are locations of various 216/235 casting codes. head casting code head date casting code block casting code block date casting code Engine Serial Number All those codes should allow you/us to ID the size and date. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | A quick easy way is to look at the engine side covers to distinguish 216 or 235. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | . . a stock 6cyl is a 216.5 or 235 . . You have a 3100 1953, the only engine from GM that year on a 3100 was a 216.5 | | |
