| | | Forums66 Topics128,259 Posts1,058,301 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I have been thinking about putting my old oil bath air cleaner back on for a more original look. I stored it for about 10 years so it's very dry at this point. The horse hair mesh in the filter is dried out and some of it shakes off. Should I be concerned that some of this loose filter mesh will be sucked down the intake or do you think that it will be captured in the oil at the bottom of the base of the air cleaner? Also I've been thinking of modifying the oil bath to a paper filter. I found this on a Ford site. Looks like it's a good modification. http://www.ford-trucks.com/forums/1063658-drying-out-the-old-oil-bath-air-cleaner.htmlMark | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | A fram CA148 will replace the oil bath element nicely. No cutting involved.
Ed
| | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I'll check this out. Thanks Ed. | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | How do you use a Fram CA148 without cutting open the oil bath air cleaner? I have a 1949 3100 with the 216 cu.in. engine. My oil bath air cleaner where the fiber filter is located is sealed. Would like to see some photos.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | It would need to be cut. At least mine would. | | | | | Joined: Sep 2015 Posts: 15 New Guy | | New Guy Joined: Sep 2015 Posts: 15 | Thanks for the original post, and for the Fram part number. The air filter was always one of my least favorite engine parts on my 57 3100, that and the oil bath oil filter. I'll probably use a turkey baster to drain that one this time, though, instead of wringing out a rag 6 or 8 times like I used to do in high school. | | | | | Joined: May 2007 Posts: 1,721 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,721 | Stovebolt search for this thread: Re: Removing the Oil Bath Air Filter?
Good descriptions and part numbers for paper filters. The link below is method I used in my 283. Happy with result.
http://home.comcast.net/~svwilbur/ChevyPU57_filter_Conversion.html | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | My air cleaner looks like this. I simply removed the entire filter element assy and replaced it with the CA148. Put cover back on and done! http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0677.htm
Ed
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Guess they must have made different styles of oil bath air cleaners? Mine is definitely sealed. Would like to get rid of the oil bath, but really don't want to cut on the original air cleaner. I'll look for one that has a lid and is not sealed. Would this still be correct for a 1949 3100 1/2 ton with the 216 cu.in. engine?
Tim
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Can't say if it's correct. Picture posted was from 48-51 shop manual.
Ed
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I see you have now added a third cleaner.
As I posted above, I also had a pre-54 big-truck air cleaner that did not look like the last one you posted/added.
There were 1lb, 2lb, and 4 lb oil bath air cleaners, not counting cleaners with PCV set-up. | | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | Tim Any oil bath air cleaner would have to be able to separate and disassemble to refill with oil. You may have a silencer/air filter that came on cars - not trucks. My 50 Chevy came with one and you could not disassemble it. The engine was from a 1954 automobile with a Powerglide transmission. The carburetor had an automatic choke and the air cleaner was welded together. Not correct for a truck. Fortunately the truck also came with a correct 235 carburetor and wire maze air cleaner. Mike | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | HB. Thanks for posting the link. That is exactly the same oil bath air cleaner that I have. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Nope, no picture, just a reference: 1949 5000 series 5000 series = COE I have a 54/55 GMC COE and it's oil bath air cleaner is an oddity, but it could be adapted to work with/on a down-draft carb. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Thanks, DADS50 (and, from my own web site).
One of the odd oil bath air cleaners I had was like tht 1508 air cleaner (Sedan Delivery).
The 5000 series air cleaner shown for 1950 is completely different from the one on my 54/55 GMC. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | No problem. You provided me those links 5 1/2 years ago | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | In case anyone is interested, here is one on my 54/55 GMC COE. It is probably a 1 or 2 quart air cleaner. | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Thanks to everyone that gave me input! What air cleaner do I look for on my 1949 Chevrolet 3100 1/2 ton pick-up that will be correct?
Tim
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Correct is the open element, 1-pint/pound or the 1-quart/2-pound I posted, your choice. | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Brad thank you!! I guess these air cleaners are rare. I haven't found any in good shape where I have looked.
Tim
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Hit a few good swap meets, I usually see a couple of the oil bath types at most of them that I go to. The standard "Flame Arrester" types show up once in a while but they are being reproduced and sold by the vendors with a little searching. Classy Chevy USA has them on their ebay store. dg
Denny G Sandwich, IL
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | A 49 216 with it's original A/C Same 49 216 w/a replacement oil bath , date & type unknown. Got it off ebay. I purchased another oil bath at a swap meet (no pic at this time) and it's different from the orange one but is similar in size. Good luck Dave | | | | | Joined: Dec 2013 Posts: 795 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 795 | I just converted my oil bath air cleaner to a paper filter element. The oil bath was a two-piece filter (click) and I didn't want to cut it up, you just never know..... I found a decent three-piece top on EBay for ten bucks and installed a NAPA FIL 2193. It's 4" tall and fills up the oil bath reservoir (click). adequately. Hope this helps, good luck! | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I have several of the stock 1950 half ton oil bath filters that I can part with if anyone needs one. I decided to keep watching Ebay for the original style Air type filters and replaced all mine with those using a new style filter. Like these: http://devestechnet.com/Home/AirFilterThe document is obviously incomplete but has what I have done regarding this issue. | | |
